new PipeMax version 4.70
maxracesoftware
Post by maxracesoftware »
new PipeMax version 4.70 Download Link :
https://www.mediafire.com/file/viwxszuo ... 0.zip/file
PipeMax v4.70 Download-Install-Register to receive your UnLock Code
Download and Install PipeMax v4.70 then Register to receive your UnLock Code
( please read entire webpage about PipeMax at this Link )
http://www.maxracesoftwares.com/forum/v ... f=14&t=263
After you install PipeMax , please Register from inside the PipeMax program
by clicking on [ Register_Activate ] button in the Menu Bar ,
that Button will open the PipeMax Registration Screen Window.
Required 5 Lines of your Computer's Information to receive your UnLock Code :
these 5 Lines of your Computer's information are automatically created by
your Computer inside PipeMax at the time you startup the PipeMax program .
After you Open the PipeMax Registration Screen, you will see that
these 5 Lines were automatically created and filled-out for you !
1=Serial Number of Drive = ?
2=Installed Path = ?
3=Locale ID = ?
4=User Name = ?
5=Computer Name = ?
each Computer has its own unique Registration Information
For every Computer you install and Register PipeMax on ,
you will need its very own unique UnLock Code for each specific Computer .
the UnLock Code must match the exact Computer you installed PipeMax on !
follow all the instructions and fill out all the Registration Form completely
then click the [ Register OnLine ] button to submit your Registration information,
so i can email you back the correct UnLock Code for PipeMax .
each UnLock Code must matchup to the exact Computer it was Registered under.
the UnLock Code will only matchup and UnLock that one specific unique Computer
for each and every Computer you install PipeMax on
you must Register that specific Computer
so i can Email you back its very own unique UnLock Code
MaxRace Software
maxracesoftware
Re: new PipeMax version 4.70
new in version 4.70 :
[1]= fixed "Bug" in Header TAB Page
for different Header Tube thicknesses
[2]= eliminated a few steps to get the correct
Weather Correction Factor to correlate
with changes in VE% and Cylinder Head Flow CFM inputs
[3]= VE% input value now changes with
each change in Cylinder Heads Intake CFM Flow input value .
In other words , everytime you change Cylinder Head's
Intake CFM Flow input value , the VE% value will be [ AutoCalc ]
and the Exhaust Port Flow value will be [ AutoCalc ]
[4]= added new Help Text for each of the above changes
[5]= changed Video Player in v4.70 to HTML5 standards
because Adobe Flash Player ended in Jan 2021
new v4.70 no longer uses Flash .FLV
only supports .MP4 files
MaxRace Software
