Suggestions for Engine Tuning
NormS
Post by NormS »
Basic tuning adjustments to your racing engine should be made in a specific order. This applies to the firing of a new engine, installation of a new or different carb, periodic checking of normal tuning adjustments, or searching for the cause of an engine performance problem.
Before making adjustments to the carburetor, ignition timing must be properly set. Ignition timing affects the how the carburetor works through the entire RPM range of the engine, but most noticeably in the lower part of the range. Getting the timing right is a very important first step. There are many things that should be considered when determining the correct ignition advance, including fuel octane, compression ratio, camshaft duration, and flame travel characteristics of the combustion chamber/piston dome configuration, just to name a few. If you don’t know what the proper ignition advance is, consult with someone who has adequate knowledge of your engine combination. Getting it right affects how the carb meters fuel and how the engine runs. Once the timing is set right, you can then proceed to carb adjustments.
Carburetor adjustments should be done in a specific order to keep from going around in a circle with your adjustments. First is fuel pressure. Assuming that you have an adjustable fuel pressure regulator, set the pressure to what’s recommended. Next, set the float levels to the bottom of sight holes, or the middle of the sight windows, on the side of each fuel bowl, with the engine running. Contrary to what is plastered all over the internet, setting fuel pressure and float levels MUST be done with the engine running. Most regulators and needle/seat /float mechanisms require a small amount of fuel flow to set properly. The amount of fuel that an engine uses at idle is enough to satisfy this requirement, assuming that all of these components are in good working order. Next is idle mixture. With the engine up to full operating temperature, set your idle mixture needles for your best idle quality, usually with all of the needles out the same number of turns. You may need to make minor adjustments to the idle speed during the idle mixture adjusting to keep the idle speed in its normal range.
To recap, here’s the proper order:
1) ignition timing
2) fuel pressure
3) float levels
4) idle mixture and idle speed
Checking and adjusting these items, in this order, can prevent fuel related engine performance problems from showing up at the track with you, and can help determine the causes of problems when they crop up. If you change your ignition timing in your search for better engine performance, you will probably need to readjust your idle mixture and idle speed. If you change your fuel pressure, either up or down, you should always check and reset the float levels. If you raise or lower your float levels, you may need to readjust your idle mixture and idle speed. All of these things are dependent on each other, and the performance of your engine depends on all of them being set correctly.
If you are dealing with an engine performance problem, and the adjustments discussed above do not correct the problem, then there are a number of other items that need to be checked. Carburetor related items include leaking power valves or power valve gaskets, calibration orifices clogged by dirt or other foreign matter(teflon tape), corrosion causing clogging or leaking, overheated fuel, contaminated fuel, stale fuel, cracked or shrunken o-rings on needle/seat assemblies, torn gaskets, use of the wrong gaskets (baseplate, metering block), inaccurate fuel pressure gauge, diaphragm in the regulator too stiff from heat and age, kinked or collapsed fuel line, just to name a few. There is also a long list of engine related items that can cause problems. My experience has been that problems are often a result of multiple causes. Finding and correcting one cause may not totally solve the problem, so keep searching until you have corrected all of the items that are contributing to the problem. (Sorry, more easily said than done.)
© Norm Schenck/Comp Fuel Systems
Competition Fuel Systems Birch Run,MI. www.compfuelsystems.com/index.html 520-241-2787
