Has anyone built a 350 oldsmobile approx 300-350hp?
I have a customer that wants to build his 350 olds up he wants it for a street car with the stock #7 cast iron heads & to run on pump gas.It also has power brakes and he is trying to get close to 350hp i see these are real low comp engines what pistons are you guys using to get around 9-1 he is also using a 650 holley carb & headers
- Wolfplace
Re: Has anyone built a 350 oldsmobile approx 300-350hp?
=drifter wrote:I have a customer that wants to build his 350 olds up he wants it for a street car with the stock #7 cast iron heads & to run on pump gas.It also has power brakes and he is trying to get close to 350hp i see these are real low comp engines what pistons are you guys using to get around 9-1 he is also using a 650 holley carb & headers
Probe has a very nice flat top for these, just did one but it was not dynoed.
If you are not a Probe dealer I would be happy to help you.
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
I am not sure if these are available at this time, but here goes. SpeedPro L2321F dished piston for ~ 9.5:1 compression ratio with 64 cc head. SpeedPro L2320F flat top piston just over 10:1 compression w/ 64cc head. Both rated with a .025" deck clearance.
That #7 head was available with small and large valves, depending on the application. 1.880"/ 2.000" intake and 1.567"/ 1.625" exhaust. I believe W-31 engines had the larger valve option.The SBO castings are quite choked up as cast, but respond well with bowl /SSR work , some reshaping and a real valve seat profile.
Hope this helps.
Hope this helps.
I have done a couple of 403 Olds engines that ran quite well with the lower compression pistons, cam was a little tricky as the fulcrums on the rockers are not really set up for High Perf, it did repond very well to opening up a stock Qjet carb intake, I made it a double plane but removed the material from one bore to another.
the #7 head only came with one of two size intakes,,early 71(#7)&72(#7a(thats small "a") heads got the 1.875&the the late #7A, 1985 got a 1.750.FEnut wrote:I am not sure if these are available at this time, but here goes. SpeedPro L2321F dished piston for ~ 9.5:1 compression ratio with 64 cc head. SpeedPro L2320F flat top piston just over 10:1 compression w/ 64cc head. Both rated with a .025" deck clearance.
Hope this helps.
the early heads with the 1.875 intake and 9.5:1 is an easy 350 hp with the right cam&performer rpm. cast pistons are fine for this, just make sure you get the comp ratio correct as the comp heights can be shorter than the factory spec.
- Wolfplace
.100 taller,, yea I think it might be a little prouddrifter wrote:Has anyone tried a 455 piston would it stick out past the deck i found one thats a 1.720 ch
Nominal deck is 9.330, rod is 6", stroke is 3.385
If you did not deck it at all you would be about 80 thou out
I don't understand why you are making this difficult,, it a pretty straight forward build with a very nice reasonably priced forged piston.
Mike
A tour of my shop
The Dyno
John Wayne
A tour of my shop
The Dyno
John Wayne
Looking for a cast or hyper piston perhaps?
Pontiac 428 piston would fit the general parameters. STD would be .063" over. Not sure about the valve reliefs though.
Really the 403 block is the way to go, only thing needs to be done to use the much better old 350 heads is to drill the head bolt holes out to 1/2 inch.
It look just like a 350 motor but have 50 CI more.
I was in to those Olds motors at one time and my shop teacher did that to his Olds Cutlass car. Work very nice and he had 350 stickers on the air cleaner
