Stock and hopped Z-28 engines here..
Post by pdq67 »
Just how much power did these little old engines really make?
I made a junk 301 that I figure was only like only 325 hp..So know a little bit about them.
bigmike
Re: Stock and hopped Z-28 engines here..
Post by bigmike »
Been a number of years but my mostly stock rebuilt 302 plus .030 over 68 Z/28 made about 351 HP on the dyno with no accessories, electric water pump used on dyno only and headers.
Post by F-BIRD'88 »
There was a hot rod mag article that covered just that about the 302 Z/28 engine . Dyno tests in both restored stock oem form and also when modern hot rodded (aftermarket heads, intake, roller cam, headers) I believe the all stock motior was 350 hp and the hot rodded version was 550-560 hp.. If memory serves. Do a search. It was online.
Post by pdq67 »
Little suckers would rock and roll, imho...
Truckedup
Post by Truckedup »
Stock ones from the dealer were not all that fast, maybe mid to low 14's ...
Little Mouse
Post by Little Mouse »
Have an old rag that tested the 69 Z/28 against the 69 boss 302 mustang. They claimed both cars ran identical 14.98.
bpenrod
Post by bpenrod »
vortecpro
Post by vortecpro »
bigmike wrote: Sat Oct 10, 2020 11:31 am Been a number of years but my mostly stock rebuilt 302 plus .030 over 68 Z/28 made about 351 HP on the dyno with no accessories, electric water pump used on dyno only and headers.
YES
Jeff Lee
Post by Jeff Lee »
Interesting article; roller cam, aftermarket heads, intake and carb and just about the HP output of a Stock Eliminator 302 SBC.
Have a friend building a ‘70 Boss 302 Stocker. Expecting north of 550 HP. Time will tell.
NHRA SS/G
1970 AMC AMX - 390 4-speed
BILL-C
Post by BILL-C »
A good SVRA spec vintage TRANS AM ford 302 and chevy 302 will both make 600+ HP and 420 TQ in road race trim. Iron heads (aftermarket allowed), dual plane intake, roller valvetrain, and 310 max cid. They also need to survive for hours with a brick on the gas pedal at 8 k rpm and survive the occasional 10 k rpm bad down shift.
Carlquist Competition Engines
1980RS
Post by 1980RS »
All the people except for one guy I grew up with those 302's were torque dogs. Never wasted any time on them when a well build 400 SBC could make more power for less.
Truckedup
Post by Truckedup »
So how much power at the flywheel did the factory stock Z28 engine make as installed in the car on the factory assembly line?
englertracing
Post by englertracing »
1980RS wrote: Sun Oct 11, 2020 11:20 am All the people except for one guy I grew up with those 302's were torque dogs. Never wasted any time on them when a well build 400 SBC could make more power for less.
Yeah pdq has some delusion that a short stroke is an advantage....
All it does is make the port look larger compared to the displacement.
Post by F-BIRD'88 »
Truckedup wrote: Sun Oct 11, 2020 12:07 pm So how much power at the flywheel did the factory stock Z28 engine make as installed in the car on the factory assembly line?
You can know this by finding the 1/4 mile drag test MPH and the true test weight with driver of a all stock '67-'69 Z/28 Camaro.
EG: 290 hp net as installed rated power and #3500/ #3600 weight with driver goes 101-102 MPH 1/4 mi.
Post by F-BIRD'88 »
Most people will not gear their car up high enough to fully use the high rpm power band of a small cid v8 like a 302.
They won't run the long duration cam nor the high rpm induction system needed . Especially on anything that gets street duty.. The powerband is pretty much 5000+ and up (8000-8500 rpm)
