any 912 porsche gurus here
jred
Post by jred »
Got a customer that's brought in his 67 912 Porsche engine to do, The only problem is he's lost or thrown away the crank flywheel connecting rods and cam for it.
So far I have been able to find everything except the cam,,
I have found some new cams at web cams and have talked to Jerry Cantrill at Schinder cams, but a lot of the cams are 240 plus at .050
I am trying to find out what the stock camshaft numbers are to compare too,
Any info or some body that has cam doctored a stock cam thanks for any help on this..
David Redszus
Re: any 912 porsche gurus here
Post by David Redszus »
jred wrote: Mon May 09, 2022 11:06 am Got a customer that's brought in his 67 912 Porsche engine to do, The only problem is he's lost or thrown away the crank flywheel connecting rods and cam for it.
I have CamDr data for my porsche 356SC. However, it is measured at the cam and not at the valve.
Being a push rod engine, it has little value except for comparison purposes.
I would suggest that you contact
NeuTekcams.com
They have original cam blanks and finished cams as well.
Another source is Vic Skirmants. 356Enterprises.com
Vic knows these little four bangers as very few others do.
He may have a collection of used cams for the 912.
dannobee
Post by dannobee »
jred
Post by jred »
double post
jred
Post by jred »
David Redszus could you please share the info on your stock cam and thanks to both of you guys for the info and contacts I myself used to do a lot of air cooled vw's and have a 2443cc air cooled vw with a lima case counterweighted crank that is wedged mated turbo with 2 IDF throttle bodies with Megasquirt 3.0 and ford edis system..
thanks again for the leads..
David Redszus
jred wrote: Tue May 10, 2022 12:28 am David Redszus could you please share the info on your stock cam and thanks to both of you guys for the info and contacts I myself used to do a lot of air cooled vw's and have a 2443cc air cooled vw with a lima case counterweighted crank that is wedged mated turbo with 2 IDF throttle bodies with Megasquirt 3.0 and ford edis system..
Sorry to report that the Cam Dr file for the 356 camshaft is on a computer under repair at the momement.
