This question refers particularly to BBC with the long water pump when using a clutch fan. I have seen small block chevy 1.5 inch spacer OEM without a fan clutch . Can't remember any BBC with a fan spacer.
Will a fan spacer with a fan clutch cause harmonics/vibration leading to water pump bearing failure?
Fan spacer
Re: Fan spacer
It is all about weight cantilevered of the front of the water pump.rgalajda wrote: ↑Sun Jun 05, 2022 6:17 am This question refers particularly to BBC with the long water pump when using a clutch fan. I have seen small block chevy 1.5 inch spacer OEM without a fan clutch . Can't remember any BBC with a fan spacer.
