MSD 7al-2 to a MSD 8 box
Would there be any HP and TQ benifits from going to the MSD 8 over the MSD 7al-2 box? Its on a 522 big duke motor on race fuel. 15 -1 CR. More info needed just say so.
522ci-1803Dukes-cast intake,single 1250 on gas-1108hp. heads by cboggs
NTPA SS4X4 RIII
NTPA SS4X4 RIII
MSD 7AL2 vs MSD 8
Obsessed
We did some work last season with several customers doing an A-B compare of just what your asking about. They wanted a plug & play swap and did not want to go the Digital 7 route. First off the benefits dropped away on any motor under 12 to1. As mentioned above the current draw of the MSD 8 is much higher so the battery / charging system has to be stout for full kill !!! You have to plan on rejetting and resetting timing to adapt your program to the boxes output. Performance found was two fold, First: the engine would rev up quicker just as if you swapped to a lighter flywheel. Second: we were able to gain 10 to 15% improvement on the dyno once the jetting was right. These improvements were confirmed on the track by two drag cars, two circle track cars and one tractor puller. As mentioned above MSD has MSD 8 Plus coming out this season, it has the same toys as the 7AL2 Plus for Drag racing. I hope this helps you with your quest! Have a good one......
ep33510
ep33510
Pat Collins
TechWest Racing Services
Helping Racing Adapt to The Unknown
MSD®Ignition Upgrade & Repair Service
704-995-4286
techwest@techwestracing.com
http://www.techwestracing.com
704-995-4286
Re: MSD 7AL2 vs MSD 8
ep33510 wrote:Obsessed
ep33510
Thanx, My engine is at 15-1, also I dont need all the bells and whistles of the digatal or programmable stuff. As far as my charging sys I have 2 1000amp batteries hooked together along with a 100amp alt. Might be worth trying
NTPA SS4X4 RIII
NTPA SS4X4 RIII
MSD 7AL2 vs MSD 8
OBSESSED,
If you have the money for the move to a MSD 8 I would consider it an option. With the spec's you mentioned about the battery & charging system, it is right on the mark for stout!!! Like I mentioned on my last post, if you do want to go this direction try and score the new MSD 7805 which is the MSD 8 Plus. The coil should be a MSD 8261 to get everything out of the box. My tractor puller customer moved from a Mag setup to the MSD 8 and had fun last season messin with the Big Kids Day!!! Catch ya Later!!
Pat Collins
704-995-4286
704-995-4286
Re: MSD 7al-2 to a MSD 8 box
Another zombie thread. It's been dead for eleven years.
Monty Frerichs
B&M Machine
B&M Machine
Yes, another zombie reemerges, but the Similar Topics feature can be very useful in bringing 'filed and forgotten' info to the surface. Granted, asking: "So how did it run?" 12 years after a guy's planned strip test is unproductive, but much of such thread content is of ongoing value to members old and new.
After double-digit years as a Speed Talker I still find numerous relevant posts there that I missed first time by...
