Chinese look a like Little-M block
CNC BLOCKS
Post by CNC BLOCKS »
We have one in shop right now and have looked it over and checked it for brinnel test and it seems to be a very soft block as it tested in the low 140's
To give you an idea a 010 block is around 180ish and SHP block tested mid 190's and the Little-M and Big-M are mid 230's because of the nickel content.
It lools like the block is finished honed and I have not probed it out for locations for deck heights, cylinder bore loctaions, lifter bore locations ETC.
Looks like once the cylinders were honed they decked the blocka nd left a burr at the top of the cylinder as there is a zero chamfer on the tops of the cylinders.
The lifter bores have a huge ridge at the top and on the bottom of the bores I would assume from machining the soft cast iron.
With that soft of bore it would wear the cylinders out in a short time as well as the lifter bores.
The rear main cap is not even flat where the pump sets on and they have welded what it looks like a insert where the threads are.
I will post pics later on and what we find for demensions in another thead.
For right now it does not look like a very high end peice and is surely a copy cat of the Dart Little-M block
I beleive PBM is selling them with their name on them!!
I meant to post this here and not the advanced forum Sorry
Website is up and running
Machine shop tour
Monthly Specials
PFC1
Post by PFC1 »
Surely it was not a PBM deal. I just looked over a PBM block last week and it appeared to be a nice looking piece. It had billet caps that had PBM milled on them and all ARP studs. I was positively told they were cast in New Zealand, because I questioned whether it was a Chnese casting and was assured they were not.
That's about all I know... hope I was told the facts. Bret
Pullin' for Christ
Keith Morganstein
Re: Chinese look a like Little-M block
Post by Keith Morganstein »
CNC BLOCKS wrote:We have one in shop right now and have looked it over and checked it for brinnel test and it seems to be a very soft block as it tested in the low 140's
Be concerned about that. I hear the same about the chinese cast iron heads.
I seriously doubt the block you have is cast by Toowoomba Metal Technologies as those casting are high quality. Toowoomba Metal Technologies currently does NOT list engine blocks a product.
needforspeed66gt
Post by needforspeed66gt »
Keith Morganstein wrote: I seriously doubt the block you have is cast by Toowoomba Metal Technologies as those casting are high quality. Toowoomba Metal Technologies currently does NOT list engine blocks a product.
+1
Very nice castings.
Nate @steeldustmachine
Engine Machinist
CNC BLOCKS
PFC1 wrote:Surely it was not a PBM deal. I just looked over a PBM block last week and it appeared to be a nice looking piece. It had billet caps that had PBM milled on them and all ARP studs. I was positively told they were cast in New Zealand, because I questioned whether it was a Chnese casting and was assured they were not.
From what I was told those blocks like the one I have in my shop and a shop is Florida is machining the caps to say PBM on them.
Machine shop tour
Monthly Specials
DCK
Post by DCK »
+1
Very nice castings.
+2, The EQ's I have were pretty nice out of the box and I believe, not 100% sure, they are cast at that foundry.
needforspeed66gt
DCK wrote:+2, The EQ's I have were pretty nice out of the box and I believe, not 100% sure, they are cast at that foundry.
Correct.
Engine Machinist
xanadu
Post by xanadu »
Maybe a question to the person who wished to obtain your services will be able to answer a question or 2?
How much money would a company save on a production of engine blocks with a low Nickel content giving a lower than std. hardness / opposed to a block with a high Nickel content giving a higher hardness.
Sounds like the last Chroming company i got to do my bumper bars.
CNC BLOCKS
xanadu wrote:Maybe a question to the person who wished to obtain your services will be able to answer a question or 2?
This will be the only block of this kind that will be at my shop as it does not look like a quality peice to me.
Machine shop tour
Monthly Specials
xanadu
Post by xanadu »
Sounds Serious! To your Credit, it sounds like no one can pull the Wool over your eyes.
It's people/businesses like you that keep quality on the board and the Crap in the trash.
If i may say so. Well said and well done! :D
Keith Morganstein
Are you even going to machine it?
Please post some photo's so we can identify these blocks.
Keith Morganstein
From what I can research, PBM and Pro Comp blocks are different.
One is a $1000 chinese block and the other is $2155. New Zealand casting
PRO COMP is chinese and cost around $1000.
here is an ebay link
http://cgi.ebay.com/ebaymotors/ws/eBayI ... tsupported
PBM blocks are made under by Haigh Engineering in New Zealand....Haigh originally bought the small block Rodeck moulds. There was thread on Haigh here before.
they cost $2155 for the kit
http://www.pbm-erson.com/store.php?catId=754
The new PBM Small Block Chevy iron race block has features not available on other aftermarket blocks and is priced at a sportsman price.
* High Nickel Alloy Casting
* Block Clearanced for 4" stroke
* Billet 4 bolt mains caps w/ ARP studs
* Machined for bolt-in screen (included with block)
* Priority main oiling
* 2" bore cam tunnel (50mm optional)
* Cam bearings included
* Brass freeze plugs included
* Dowel Pins Included
* 4.116"-4.118" std bore
* Driver side dipstick
* 2pc rear main seal
ALKYBURNER
Post by ALKYBURNER »
Does anyone have a pbm block that can have it Rockwell tested to see if it does have a high brinnel figure. Not have them side by side but the only difference I can see is the Chinese one has a black coating and the pro comp has a screen bolts and engraved caps. Have seen the Chinese block and it is not even as good as a 010 block in fact a 400 block is better( hard to believe I know) The Chinese block we have at our shop and the one picture posted here has the oil pump threaded hole welded if you look close and its done after the black oxide cause the heat from welding tarnishes the black finish. I wonder what the boys at dart think of this. The Chinese one is a definite copy of theirs to a T. :roll: CNC: when are you going to have more information on this: locations,and dimensions.
CNC BLOCKS
Keith Morganstein wrote:Are you even going to machine it?
Not going do any machining on the block we have just going to check it for locations and and compare it to a Little-M block
Machine shop tour
Monthly Specials
CNC BLOCKS
Keith Morganstein wrote:From what I can research, PBM and Pro Comp blocks are different.
I think you will find you are being mislead about being made in New Zealand and PBM from my understanding is having them finished off in a shop in Florida but are the same casting from China.
I think the pitch about being from New Zealand is just a marketing scheme!!
Machine shop tour
Monthly Specials
