intake port to intake manifold. match or mismatch?h
dan miller
Post by dan miller »
You guys are doing great with the exhaust port to header flange question. How about talking about the intake side of things?
I'm from the "match it" camp.
I set the heads on the block (no valves, maybe a loose head bolt or two) and bolt on an intake manifold that has been dowel pinned. Then I remove the bolts from one side of the manifold, lift off the manifold and head, and reach up through the intake valve seat to scribe the manifold.
Danny
1989TransAm
Re: intake port to intake manifold. match or mismatch?h
Post by 1989TransAm »
I'm from the school of getting the cross sectional area of the intake runner correct for the correct velocity. Then of course no lips allowed on the head entrance. :wink:
CHT
Post by CHT »
For the EMC engine a match may work better. Do two intakes and evalutae A B A testing
cjperformance
Post by cjperformance »
CHT wrote:For the EMC engine a match may work better. Do two intakes and evalutae A B A testing
X2 on that one. Comparisons are the best, leaves less to guess work.
Craig.
CHT
Post by CHT »
1989TransAm wrote:I'm from the school of getting the cross sectional area of the intake runner correct for the correct velocity. Then of course no lips allowed on the head entrance. :wink:
X2
Ted
Post by Ted »
Recently dyno tested a street 454 BBC that had the 119 oval port heads with a variety of intakes. The rectangular port dual plane (factory Winters intake) easily outperformed the oval port Edelbrock Performer RPM. The intake port mismatch was beyond bad but both the lowend and topend numbers were better with the large rectangular port intake. Just FYI and shows that almost every combination has to be tested.
Ted Eaton
dan miller
Hello Ted
I've heard variations on your findings many times. My partner, Gene Adams, has personally seen it on a Ford 460. Small port heads with a 4 bbl carburetor, verses Cobra Jet manifold with the same carburetor - the Cobra Jet manifold made 20+ more hp in back to back tests.
We figured that the manifold was the difference (a poor but correctly matched manifold would be beaten by a good but incorrectly matched manifold). But in this case, I suspect that the Edelbrock is at least as good as the GM manifold.
It's a mystery. lol
Test. Test. Test. Hey John, do we get a discount if we're on your pump over 100 hours?
Danny
promachine
Post by promachine »
That depends on TWMIH (time with mop in hand). :)
h.p. peddler
cjperformance
promachine wrote:That depends on TWMIH (time with mop in hand). :)
:lol: beauty
Craig.
1989TransAm
Dan, it would be an interesting test to have the port of the intake manifold at the best cross sectional area and leave it as is at the head with no lips protruding from the head of course. Make a dyno run or two. Then blend the intake manifold port at the head end to match the entrance to the head intake port entrance. Then run a dyno test to see if there is any difference. Hey it is only your money and dyno time. :mrgreen:
CHT
Post by CHT »
It'd be interesting to see Dan do numerous intakes 1 matched, 2 +0.050, 3 +0.075, 4 +.100, 5 +.125, he'll be going for months. :lol:
Kdub
Post by Kdub »
The big mismatch made the oval port head think it was feeding from a larger plenum manifold? The bigger runners on the square port heads would make the manifold have more volume.
T-flow
Post by T-flow »
Kwilliams, hit it on the head! One intake has a bigger CS and feeds the intake track better. Even with the mismatch...
T-flow Cylinder Heads
www.tflowheads.com
Ron Miller
Post by Ron Miller »
kwilliams wrote:The big mismatch made the oval port head think it was feeding from a larger plenum manifold? The bigger runners on the square port heads would make the manifold have more volume.
kwilliams,
When you say big mismatch,,,,, did you leave the intake oval port shape oval ?? or did you possible grind a funnel shape(head side oval to square) to match the square port intake shape ??
I have seen this done before and wondered if this would help or hurt the air transition from the intake into the port.
Thanks for looking
Ron
Ron Miller
Troy Patterson
Post by Troy Patterson »
Consider that the primary air stream or flow isn't spread uniformly across the port area, a majority of the flow occurring in a much smaller area and taking a path something like a string pulled through the port would take. Where the port mismatch exist may have a very small effect on the primary area flow area.
Troy Patterson TMPCarbs.net TMP Carbs
