Whats Your Definition of a Engine Builder
Re: Whats Your Definition of a Engine Builder
How about a guy that knows how to spec a cam to do what he wants it to do that works with all of the given parameters vs. selecting a "3/4 race cam" or a "medium torque cam" or even "two cams down from an rv cam" from somewhere towards the bottom of the page
Live in such a way that those who know you but don't know God will come to know God because they know you.
CamKing wrote:Someone who can degree in a cam.
Geez... that's pretty generous. I'm a backyard assembler at best, and I only work on my own junk. Even I've degreed 4 or 5 cams over the past 20 years.
you forgot the "smooth idle full race" cam? when in doubt, just go to the bottom of the pageswatson454 wrote:How about a guy that knows how to spec a cam to do what he wants it to do that works with all of the given parameters vs. selecting a "3/4 race cam" or a "medium torque cam" or even "two cams down from an rv cam" from somewhere towards the bottom of the page
Use it up
Wear it out
Eat it all!
-the greatest..."Dale Armstrong"
Wear it out
Eat it all!
How about: knowing when, where, and how to spend a customer's money to get the most effective package at a reasonable cost that meets or exceeds expectations reliably?
Indeed I did. Good oneraynorshine wrote:you forgot the "smooth idle full race" cam? when in doubt, just go to the bottom of the pageswatson454 wrote:How about a guy that knows how to spec a cam to do what he wants it to do that works with all of the given parameters vs. selecting a "3/4 race cam" or a "medium torque cam" or even "two cams down from an rv cam" from somewhere towards the bottom of the page
Malvn wrote:I often wondered what many consider the definition is of a engine builder??
Jon Kasse
DD
BORN RIGHT THE FIRST TIME
That's kind of like saying the definition of a race car driver is "Jimmie Johnson" or the definition of a pilot is "Neil Armstrong" or the .................. well, you get my point. He kind of sets the standard up there a ways. a looonnnnnng ways.DrillDawg wrote:Malvn wrote:I often wondered what many consider the definition is of a engine builder??
Jon Kasse
DD
900HP wrote:That's kind of like saying the definition of a race car driver is "Jimmie Johnson" or the definition of a pilot is "Neil Armstrong" or the .................. well, you get my point. He kind of sets the standard up there a ways. a looonnnnnng ways.DrillDawg wrote:Malvn wrote:I often wondered what many consider the definition is of a engine builder??
Jon Kasse
DD
Your right and you got my point. There are a lot of builders right up there with him but a lot of people who think they are builders are not .
By the way I know I am not one.
DD
You'd be suprised how many people who call themselves engine builders, think you just need to line up the dots.novadude wrote:CamKing wrote:Someone who can degree in a cam.
I get calls from them all the time.
Ha Ha...Perfect!k-star wrote: (don't mix up clutter or alot of work laying around with dirty)
Dots, what dots??CamKing wrote: You'd be suprised how many people who call themselves engine builders, think you just need to line up the dots.
I.M.O. a guy that delivers an engine that has great results.
B F Evans Ford Race Parts
270-278-2376
270-278-2376
Not the guy that says, "Gonna screw me sum motors tagather taday." I quit working for him, he sucked, cursed my mother, and lost the only decent employee he had, and he learned all he knew from an old Smokey book, Speed secrets.
Best engine builder i ever knew personally has retired, he was a relic, propeller head from the 50s, he was so clean and organized, used white drop cloths and laid every part out, anyway you get the idea.
mikeeebikey@yahoo.com
Drag racers prayer:
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
Drag racers prayer:
GM's engine builders don't machine everything.CNC BLOCKS wrote:X2 and guys who have to farm everything and do no machine work or buys everything out a box I would call an engine assembler.Mike Rogers wrote:Some one who designs ,machines and assemble the engine.
There is surly a differance between the two.
This should be a good debate!!!
Saying if they have someone do the machine work would be just like saying, IF YOU SEND HEADS OUT TO GET PORTED your not an engine builder, and most engine builder do send heads out to get ported. Also shops I know that do it all (except head porting) have a dedicated engine builder in house and dedicated machinist who does ALL THE MACHINE WORK
IMO an engine builder is one who does assemble the engine and makes mods to the parts being used, adjusts clearances from factory and can use aftermarket or any part to make the engine a winner
An assembler IMO are like dealer guys who only use GM and dont check clearances and usually an engine builder corrects the problem when there is one.
Someone such as yourself IMO is the engine builder and machinist.
What if the dots are offCamKing wrote:You'd be suprised how many people who call themselves engine builders, think you just need to line up the dots.novadude wrote:CamKing wrote:Someone who can degree in a cam.
I asked a "builder" how he degree's the cam with no degree wheel. He puts the balancer on and makes sure it lines up to 0 and removes it to see if its dot to dot
