If you could print any engine you could imagine
SchmidtMotorWorks
Post by SchmidtMotorWorks »
OK so we covered the worst engines.
If 3D printing ever becomes what the media are promising and you can print any engine that you can think of, what engine would you print that you can't buy today?
Then, what would you put it in? I guess you could print that too.
SchmidtMotorWorks
Re: If you could print any engine you could imagine
I'll start; I would make a 135 degree bank angle V8 2-stroke super charged (no crankcase pumping).
The 135 degrees bank angle allows for a smooth firing order.
lorax
Post by lorax »
SchmidtMotorWorks wrote:I'll start; I would make a 135 degree bank angle V8 2-stroke super charged (no crankcase pumping).
Same idea except I might go with a pancake layout.
Don't try to race it anywhere. Virtually every racing org on the planet is wise to that idea.
barnym17
Post by barnym17 »
offy just so I could have one.Actually I would love an engine with the sbc bottom end and oiling system, (beefed like a dart block).Raised cam hieght, Ford cleveland style heads with multiple bell patterns on the rear.
cv67
Post by cv67 »
Id like to see something like the LT5 come back into production
Larger bore touch larger on the stroke
Better upated head
DOHC with variable valve timing direct injection. Turbo??oh yeah.
Ron E
Post by Ron E »
I'd remake the Viper motor as a stretched new style hemi V10. 650 or so N/A HP. And there would always be the option of boost.
ap72
Post by ap72 »
something really small.
I know just about everyone on here wants a bajillion cubic inches and eleventy gazillion horsepower but I'd be happy with a really well built turbocharged 4 cylinder with top notch metalurgy and improved design so the thing could make 400-500hp and still last 100,000+ miles. It could even be SOHC with port injection and fixed valve timing. Something like a Ford 1.9L semi-hemi engine but with much better metallurgy and more attention paid to durability rather than cheap production.
I bet I'm the only SOB that would like to see that engine improved but it was a pretty straight forward and effective design- something to be said for simplicity.
LOL, according to the post count I'm an "expert." The only thing I'm an expert at is asking questions.
6sally6
Post by 6sally6 »
A 426 Hemi with a tunnel ram...capable of 30+MPG and priced under $2000.00!
Being a FoMoCo guy....427SOHC with big induction still arouses me quite abit!
"If yer gonna dream...dream BIG"!!
6sally6
Kenova
Post by Kenova »
Sixty degree V12, cam in block, .904 roller lifters, 427 - 488 cu. in., five head bolts per cylinder, symmetrical port layout with up to date ports, and extra attention paid to the cooling system design.
Stuff it into an early Monte Carlo. That huge engine bay is just screaming for a V12.
Ken
Over the hill but still learning!
Retaining it is the hard part.
flyingwedge
Post by flyingwedge »
Slide valve,.37" travel, 4 cycle, headless, 2 rods on common journal @ 120 deg separation. Triangle shaped motor would have 3 pairs of opposed cylinders, would definately be "pancake", and better suited for verticle shaft. Rev like F1, with no valve train crashing. This "is" dreaming out loud-right :?: flyingwedge.
blykins
Post by blykins »
barnym17 wrote:offy just so I could have one.Actually I would love an engine with the sbc bottom end and oiling system, (beefed like a dart block).Raised cam hieght, Ford cleveland style heads with multiple bell patterns on the rear.
Basically an LS....SBC bottom end with Cleveland heads...
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
Custom Ford Windsor, Cleveland, and FE Street/Race Engines
CGT
Post by CGT »
What is Cleveland about an LS head? The bolt pattern? Or SBC about the bottom end?
blykins
Post by blykins »
Haha, what isn't Cleveland about an LS head.....
I will give that to you about the SBC bottom end though, but the LS stuff that I've done all have had 2.000" and 2.100" rod journals.....hence the comment.
Lykins Motorsports
CGT
Post by CGT »
Blykins, I wasnt being sarcastic, just curious. I know the bolt pattern is the same, just didnt know what else. A LS is a wedge, a Cleveland is not, right?
blykins
Post by blykins »
Bolt pattern is the same, and if you compare LS7 heads to 4V Cleveland heads, lots of other things are very similar....port dimensions, port shape, valve diameters, etc. I think you could probably even bolt an LS intake up to a Cleveland...
A Cleveland head is a canted valve head. The closed chamber head is a wedge style.
To chip in and not be a total hijacker, I'd like to see some actual CG Ford FE blocks come to fruition. Pond has had them advertised on his website for awhile, but to my knowledge, none have been made. Some really big FE's would be pretty sweet.
Lykins Motorsports
