I have switched from a mechanical flat tappet to a mechanical roller and noticed a drop in oil pressure.
I have checked the main & rod bearings and all clearances are still within spec as prior to cam swap.
The pressure at idle used to be 20-25psi (hot), but is now 10-15psi.
I have my oil pressure sender tapped into the front-most main gallery plug, furthest from the pump (big block Chevrolet) as to always see the worst case scenario so, I decided to switch it to the rear-most plug, closest to the oil pump, and saw less than a 5lb difference indicating to me that I was not losing excessive pressure/oil from the bottom-end. (Fair assumption?)
I have continually used the same Mobil 1 15W50.
The only changes that were made to this engine is the installation of the roller cam.
The lifters are Isky RedZone lightweight 272-96-RHM. Because these lifters have pressure fed oiling to their rollers, is it expected they consume considerably more oil (and therefore pressure) than regular flat tappet lifters?
Is this where my oil pressure has gone?
I am lost as to why my oil pressure has dropped.
With such a drop in pressure, is my engine's health at risk?
Thank you for your time and help.
