Ball bearings, no lube?
clshore
Post by clshore » Tue May 26, 2015 4:10 pm
No grease or oil?
http://www.pddnet.com/news/2015/05/japa ... cation=top
Claims that getting rid of the cage to space the balls eliminates most friction, eliminates need for lubrication.
Nikolas Ojala
Re: Ball bearings, no lube?
Post by Nikolas Ojala » Tue May 26, 2015 4:55 pm
Very nice!
I am sure that space industry will be extremely interested.
twl
Post by twl » Tue May 26, 2015 5:10 pm
Ceramic ball bearings have had that "no lube" ability for quite some time, along with lower moving mass, but the cost for ceramic bearings is probably higher.
I would pick ceramic ball bearings anyway, over these.
But, these are somewhat interesting.
Kevin Johnson
Post by Kevin Johnson » Wed May 27, 2015 4:51 am
The outer race has visible eccentricities in movement. See 1:10. I think vibration and load capacity should be looked into carefully.
clshore
Post by clshore » Wed May 27, 2015 6:17 am
Yah,
I have my reservations about this too, just posted it as an interesting 'claim'.
Post by pdq67 » Wed May 27, 2015 8:34 am
Me too!
I will wait for long term real life over-the-road tests before I comment.
If this is so, then brennelling of the race should be a good thing....
Dan Timberlake
Post by Dan Timberlake » Sat Jun 06, 2015 11:39 pm
Check out Fig 8 on page 21 here.
http://ntrs.nasa.gov/archive/nasa/casi. ... 006034.pdf
Without fully developed elastohydrodynamic ( rolling ) lubrication the balls and races will start to spall and even fail by other means at a fraction of the "standard" predicted catalog life.
I think Loads and rpm would have to be so low to take advantage of that technology as to be pretty much useless for most machinery.
Kevin Johnson
Post by Kevin Johnson » Sun Jun 07, 2015 8:02 am
Dan Timberlake wrote:Check out Fig 8 on page 21 here.
Aside:
Author uses 'absorption' incorrectly on page 8 but 'adsorption' correctly on page 2. Author corrects the error on page 10 of NASA paper submitted several years later (http://archive.org/stream/nasa_techdoc_ ... 7_djvu.txt) .
Rothbart catches and corrects this error in his earlier paper in his paraphrasing of page 8: http://www.slideshare.net/mzrzory/rothb ... whill-2004
"The extreme-pressure additives in the lubricating fluid form a film on the surfaces by a chemical reaction, adsorption, and/or chemisorption."
modok
Post by modok » Fri Jun 19, 2015 12:55 am
There is nothing in the video about not requiring lube.
The author of the article thinks "grease has been essential", means these require no lube??? author of article clearly not very sharp on comprehension.
The concept is these bearings require no cage.
Looking at the design, it appears this is accomplished by putting those grooves in the outer race, so the loaded balls accelerate away from the ones behind them, instead of the opposite.
With a ball in a groove, if the contact is on the sides it will speed up, contact at outer end it will slow down. Planetary gears and how trains run on rails! Very interesting.
Seems reasonable that normally the loaded balls will have more contact at the base of the groove and slow down.
Kevin Johnson
Post by Kevin Johnson » Fri Jun 19, 2015 6:06 am
modok wrote:There is nothing in the video about not requiring lube.
The difficulty is that the spokesperson from Coo Space Ltd. suggests and supports this conclusion:
https://www.youtube.com/watch?v=wN0vhXGVHnI
Published on Sep 1, 2012
Even if the ball of Bowling does not have wax, it rolls.
Why is grease required at a bearing?
Since the ball and the cage always rubbed, grease was required for the bearing.
"A.D.B." which makes balls non-contact without a cage is introduced.
It is the model change for the first time in bearing 500 years.
https://www.youtube.com/watch?v=gJygDep-FSQ
But in this in this additional video by Coo Space, oil is mentioned as being a lubricant with even lower viscosity lubricants contemplated. (See 4:36)
If you read the patents, there is more than one source of sliding friction discussed ("jostling" for example) so if you want to criticize Jacob Meister then it should be on the basis that he did not do this.
https://www.google.com/patents/US8052330
https://www.google.com/patents/US8783958
modok
Post by modok » Sat Jun 20, 2015 12:20 am
I am reading between the lines to some degree.
Q: Why is grease required at a (steel) ball bearing?
A:because they could not use oil
It's like asking why the chicken crosssed the road, or if the egg came first. That is too DUMB to be taken literally!!!
I am sure we all understand the basics clearly, cageless bearings are common, bearings do not all use grease, and steel rusts. He knows this too!
You can read between the lines differently if you want, but when I read the engrish what I got out of it was:
I will translate for engineers:
"why do some ball bearings often require high viscosity lubricant with a lot of EP additives? Because there is significant, and differing types of friction which requires this heavy oil, and consumes the additives in a caged ball bearing.
Our invention allows thinner lubricants with less additives to be used, because sliding friction is reduced."
