-0.015" Big Block Timing Chain
Cloyes p.n. 9-134-15 is NLA. Who if anyone makes one? (same chain fits BB Ford and Chrysler)
Malvn
Re: -0.015" Big Block Timing Chain
Post by Malvn »
Malvin
" Keep away from people who try to belittle your ambitions. Small people always do that but the really great make you
feel that you, too, can become great". By Mark Twain
Thanks malvin. Interesting; Rollmaster uses bigger sprockets instead of 'shorter' chains like Cloyes. The site doesn't mention how big they go; I'll drop them a line to ask.
They have a handy 'rule of slack' to determine how much short the c-c is; I'll compare it to my actual measurement tomorrow. One factor I'm pondering but which I've never seen mentioned is the fact that mine is an aluminum block and so at 200° F., the c-c will grow ~0.004" more than an iron one...
Schurkey
Post by Schurkey »
I thought Cloyes used bigger sprocket(s). Aren't "shorter chains" a myth?
Geoff2
Post by Geoff2 »
What Shurkey said.
EDC
Post by EDC »
Schurkey wrote:I thought Cloyes used bigger sprocket(s). Aren't "shorter chains" a myth?
Correct
Nil Satis Nisi Optimum
Incorrect. The Cloyes tech line is (479) 646 -1662, ex. 228. Call them yourselves to verify if you like but their catalog lists 9-134 as the standard length BB chain; to be followed by a -5 or -10 for 0.005" or 0.010" closer c-c respectively. When I talked to their tech yesterday he said: "Sorry, we don't make the fifteen thous. short chain anymore."
EDC
Post by EDC »
MadBill wrote:Incorrect. The Cloyes tech line is (479) 646 -1662, ex. 228. Call them yourselves to verify if you like but their catalog lists 9-134 as the standard length BB chain; to be followed by a -5 or -10 for 0.005" or 0.010" closer c-c respectively. When I talked to their tech yesterday he said: "Sorry, we don't make the fifteen thous. short chain anymore."
My IWIS Rollmaster sets show one replacement chain. Maybe Closes uses various versions but I don't use them...
pamotorman
Post by pamotorman »
can you adapt a LS timing chain tensioner. also some 4 cylinder engine use chain tensioners
Yes, Rollmaster makes 'fat' sprockets instead of short chains and claim it's a better approach.
pamotorman wrote:can you adapt a LS timing chain tensioner. also some 4 cylinder engine use chain tensioners
Great minds... and all that, pamotorman! Years ago when I first started rebuilding the engine I failed to find a 'short' chain, so I adapted a Cavalier tensioner to take up the slack, but now I've got a Cloyes two piece cover for fast cam re-indexing, and it won't clear the tensioner. Ironically, unbeknownst to me, Cloyes was still offering a 0.015" short chain back then.. #-o
cpmotors
Post by cpmotors »
Not a fan of Cloyes, but may I submit some more food for thought here Bill.
I just counted 33 links in the chains I use. To change the Overall length of that chain by -.015"=.00045" per link. That's 4.5 TEN THOUSANDS of an inch change in center to center distance per link. But we are talking Centerline Distance of the CAM/Crankshaft. Sprockets are measured at the root of the tooth vs pitch diameter like gears. I submit that Cloyes is using the usual tactics about chains when in fact they change the root diameter of the gears themselves vs attempting to making chains that alter the link center distance in Ten Thousands of an inch to loose .015" in Center to Center distance across 5.152".
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills since 2008
pamotorman
it is also a lot cheaper to change the pitch diameter of a sprocket than engineer a new chain .
ZEOHSIX
Post by ZEOHSIX »
I'm wondering if this is for your aluminum big block build....if it is you should take into consideration the additional growth of an aluminum block vs cast iron as the block is heated.......just saying.....
ZEOHSIX wrote:I'm wondering if this is for your aluminum big block build....if it is you should take into consideration the additional growth of an aluminum block vs cast iron as the block is heated.......just saying.....
Yes it is, as pondered in my post at the top of the page. I've never seen a print for my factory aluminum block, or any aftermarket ones, but I don't believe the former is changed from the iron version. An aluminum replacement for any iron block would have the same issue. I suspect it is just ignored, like P/V and squish difference for same.
