LOOKING FOR USED TITANIUM VALVES
NOT ALLOWED: Selling or reselling in a retail manner.
David Vizard
Post by David Vizard » Sun Aug 27, 2017 10:49 am
I have just managed to score a big bunch of cup car heads - namely Ford D3's and SB2's.I don't have valves for any of these nor for a whole load of lesser heads like Victors and AFR & Dart 23 degree heads. I want to try machineing down some of the bigger VALVES TO GO IN THOSE APPLICATIONS THAT UTILIZE SHORTER AND USUALLY SLIGHTLY SMAllER diameters in some high rpm dyno mules.
Also I don't have much experience machining Ti valves so any pointers on tool bit material and cutting oils would be good.
If you have an entire set maybe we could trade?
What am I going to do with these head? For a starters build the biggest practical SB Ford and Chevy motors.
I also scored a brand new set of prostock heads of about the 2010 era. A lot of work needed on these but the plan here is to build a 725 inch street motor with an EFI tunnel ram. That SOB better make 1000 streetable hp!
Looking forward to some valves (ship to Terry Walters) and comments on what you guys may like to see in the way of project builds with this stuff.
DV
Re: LOOKING FOR USED TITANIUM VALVES
Post by PackardV8 » Sun Aug 27, 2017 11:36 am
Hi, David,
Machining TI valves has downsides. Most are coated and machining, of course, disturbs that. Also, it's not particularly cost effective unless for a very oddball application. Since most of these projects you're working with, the heads had valves available, suggest trying to find those for sale as NOS.
Used/takeout TI valves show up on eBay in infinite variations of length, head diameter and stem diameter. To get help here, you might make a list of your wants for the various projects, as most won't know specifically what specs are needed.
statsystems
Post by statsystems » Sun Aug 27, 2017 1:18 pm
PackardV8 wrote:Hi, David,
I agree. Ti is a tough mother to machine. If you can, using flood cooling will help. Ti kind of acts like aluminum in that it can ball up. It dulls tooling fairly quickly.
Have fun and keep us posted.
1972ho
Post by 1972ho » Sun Aug 27, 2017 2:44 pm
j-c-c
Post by j-c-c » Sun Aug 27, 2017 4:00 pm
I thought Ti had a definite fatigue life, is this a good place to take a chance on used valves of unknown service life?
ZEOHSIX
Post by ZEOHSIX » Sun Aug 27, 2017 4:25 pm
j-c-c wrote:I thought Ti had a definite fatigue life, is this a good place to take a chance on used valves of unknown service life?
Your way ahead of the curve here just sit back and watch the thread take its course knowing what you already know.....
KnightEngines
Post by KnightEngines » Sun Aug 27, 2017 6:45 pm
David - machine Ti like you're machining good steel, lower rpm, Carbide cutter - cutters shaped for alloy seem to work best, steel cutting profiles will load up. Use plenty of lube, I use WD40/trans fluid mix.
Use a live centre with an old retainer up against the chamber face of the valve to support it & stop chatter.
To recut the sealing face rough cut it in the lathe 1st & then reface in the valve facer - trying to grind the whole lot ends badly most of the time.
Best to send them out for lock grooves to be recut.
Post by PackardV8 » Sun Aug 27, 2017 7:52 pm
TI connecting rods and valves are used in production engines with years and miles warranties, so the fatigue life is pretty far down that road.
David Vizard
Post by David Vizard » Sun Aug 27, 2017 8:04 pm
KnightEngines wrote:David - machine Ti like you're machining good steel, lower rpm, Carbide cutter - cutters shaped for alloy seem to work best, steel cutting profiles will load up. Use plenty of lube, I use WD40/trans fluid mix.
THIS IS JUST THE INFO I NEEDED.
THANKS.
DV
stealth
Post by stealth » Sun Aug 27, 2017 9:23 pm
David Vizard wrote:I have just managed to score a big bunch of cup car heads - namely Ford D3's and SB2's.I don't have valves for any of these nor for a whole load of lesser heads like Victors and AFR & Dart 23 degree heads. I want to try machineing down some of the bigger VALVES TO GO IN THOSE APPLICATIONS THAT UTILIZE SHORTER AND USUALLY SLIGHTLY SMAllER diameters in some high rpm dyno mules.
DV
Be careful some of those cup heads had very thin valve stems...6mm etc. not much of a street valve for longevity. They only needed to run dyno time a few practice laps and ONE race...then changed out for new. Some didn't make the whole race if over 500 miles either...
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man.
The Radius Kid
Post by The Radius Kid » Mon Aug 28, 2017 2:12 am
The Nazis didn't lose WWII,they just changed uniforms.Now they run the place.
j-c-c
Post by j-c-c » Mon Aug 28, 2017 7:09 am
That link has a lot of useful interesting info, thanks
David Vizard
Post by David Vizard » Wed Aug 30, 2017 12:30 pm
Jack,
this looks like my best avenue - thanks DV
Racing68
Post by Racing68 » Wed Aug 30, 2017 5:17 pm
I read an article a few years ago about a company that specialized in machining titanium. They developed cutting tools that were cooled with liquid nitrogen, and produced an increase in cutting speed and material removal. If i remember right it was around 30% increase.
David Vizard
Post by David Vizard » Tue Oct 10, 2017 5:18 pm
Cliff,
Thanks for the great deal on the set of Ti valves we traded for.
Still need some more though. If anybody has two valves that are or can be cut (I have now got the hang of machining TI stuff) to 2.1 dia. x 5.25 long x 0.343 please let me know.
Thanks
DV
