Ported Dart pro 1 pre platinum
cgarb
Re: Ported Dart pro 1 pre platinum
Post by cgarb »
Well, it was the Lunati rod's fault. That's what broke...lol.
Carnut1
Post by Carnut1 »
I actually think the Wisco piston pin boss pulled out.
631-816-4911
9:00am - 9:00pm EST
2X pin boss, pending close-up pix.
Carnut1
Post by Carnut1 »
The best I have. A blow up of original pic.
631-816-4911
9:00am - 9:00pm EST
BILL-C
Post by BILL-C »
Do i see burned up pieces of spun rod bearing in pic?
Carlquist Competition Engines
Carnut1
Post by Carnut1 »
I see some blue on the rod, I didn't disassemble post mortum.
631-816-4911
9:00am - 9:00pm EST
cgarb
Post by cgarb »
Piston would have been fine if the spiroloc didn't come out the side...lol. These destruction posts are educational and entertaining at times.
BILL-C
Post by BILL-C »
Usually a rod bearing gets burned up for whatever the reason and a rod bolt breaks. Then the rest of the rod and piston fall into the blender.
Scotty
Post by Scotty »
To me it looks like the rod tunnel is blue. So my question is if the pin boss failed first how does this then translate to the rod bearing failure?
GARY C
Post by GARY C »
I am still trying to figure out how broken parts = good head work?
user-612937456
Post by user-612937456 »
GARY C wrote: Fri Oct 06, 2017 11:02 pm I am still trying to figure out how broken parts = good head work?
Good head work on someone else plaything, blue rod B's, stroked piston, all torn up, having a good time till got hurt? Sounds familiar? Hmmm..... Dont try to "figure out how" If you play the game long enough someone is bound to get hurt
user-23911
Post by user-23911 »
I've got one that looks just the same.
Too tight in the bore , got stuck, broke the rod.
OK so what was the question again?
A shitty build?
Carnut1
Post by Carnut1 »
Builder is pretty good. Not his first rodeo but getting better. Tune may have been a contributing factor. I speced the timing and he claimed it ran better with more. The compression and quench were both far from optimum. Which is most likely the reason it needed more timing. I also gave rpm shortblock limit which was ummm not followed to the letter. Not bashing by any means but a tough learning curve for him. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
GARY C
Post by GARY C »
gvx wrote: Sat Oct 07, 2017 7:52 am
Just trying to figure out the quote under his pic on last page,"Recent R&D ( Race em and Destroy em) from a set of my heads. Way before flowbench. N.A. street stuff. Working on it M.T. Thanks, Charlie"
I always ran small cube nitrous engines from 700 to 900 horse, 7000 to 8000 rpm I just never broke anything, so is that because I didn't port my heads correctly?
user-612937456
GARY C wrote: Sat Oct 07, 2017 8:11 am Just trying to figure out the quote under his pic on last page,"Recent R&D ( Race em and Destroy em) from a set of my heads. Way before flowbench. N.A. street stuff. Working on it M.T. Thanks, Charlie"
Sorry Gary you didn't get it. That wasn't intended as being critical of you. This post was going a little sideways so I thought I would give my contribution, my comment was just a little sexual innuendo LOL
Last edited by user-612937456 on Sat Oct 07, 2017 8:24 am, edited 2 times in total.
