Engine machine shop destroyed my block
gmrocket
Re: Engine machine shop destroyed my block
Post by gmrocket » Mon May 14, 2018 5:04 pm
1972ho wrote:
Mon May 14, 2018 9:58 am
Now you all have me really curious as to bore clearances, will a bore that is .0004 or .0007 really cause an engine any real hp problems or sealing and wear problems.
Maybe not, but his was more than twice that extra...which is more critical on very small bores like he is dealing with.
Zmechanic
Post by Zmechanic » Mon May 14, 2018 5:10 pm
Lol, did you add another zero again? Just remember, in fractional decimal representation, there's one less zero! 1 thousand = 1000 -> 3 zeros. 1 thousandth = 0.001 -> 2 zeros.
:wink:
Or I suppose you could say one of the three zeros lives on left side of the decimal... :-k
John@RED
Post by John@RED » Wed Jun 06, 2018 6:29 am
MotionMachine wrote:
Mon May 14, 2018 8:24 am
I always question someone setting their Mitutoyo or other bore gages with a mic. It's completely operator sensitive for one and how accurate is that mic? If the thread adjustment is loose (mic has backlash), it may measure right on with a standard as the backlash is taken out when the standard is snug between the spindle and the anvil. But if it's just screwed out to 4.280" and locked, is it exactly to size with backlash not removed?
In my case my digital mic exactly got the piston's turn diameter that was even on the product sheet, so the digital bore gauge started from a known and good value
MotionMachine
Post by MotionMachine » Wed Jun 06, 2018 8:20 am
As gmrocket says, it's important to apply pressure on the spindle when you lock it. If you lock it when it's still on the piston, then the backlash is removed so that's fine. But if you are just screwing the mic out to a size, you need to push on the spindle when you lock it.
John@RED
Post by John@RED » Wed Jun 06, 2018 5:09 pm
Yes, sure. Moreover with my digital mic I can notice if it's still on the minimum value once locked.
QUESTION:
what about Nikasil these cast iron bores to increase the walls thickness and get the correct clearance back?
Some say that you can only apply succesfully Nikasil on steel sleeve and not cast iron bores
statsystems
Post by statsystems » Wed Jun 06, 2018 5:47 pm
QUESTION:
I know you can nikasil cast iron motorcycle cylinders. I've heard but never verified that certain people were using Nikasil on V-8 blocks in the late 1990's IIRC. I could be wrong about it though because it was an unverified rumor.
I'd be nervous about being able to surface the block after nikasil. Maybe they leave the stuff .060 or .040 down from the deck. I've seen guys deck two stroke cylinders and chip the Nikasil while surfacing.
MotionMachine
Post by MotionMachine » Wed Jun 06, 2018 5:55 pm
Nikasil can be applied to aluminum, gray iron or ductile iron sleeves. But the sleeves must be prepped properly first, no chamfered corners, only radiused. Very expensive undertaking, they can only be honed with diamonds and a profilometer is required to get the correct surface finish.
John@RED
Post by John@RED » Wed Jun 06, 2018 6:24 pm
Only sleeves? No directly on the bores?
statsystems
Post by statsystems » Wed Jun 06, 2018 6:29 pm
Maybe that's what it was...they were using sleeves that had been nikasiled. Maybe Warpspeed can answer the question.
cgarb
Post by cgarb » Wed Jun 06, 2018 6:38 pm
Rather than spend a mint trying to Nakisil cylinders...couldn't you just order another set of pistons say .002 or .005 over the size now and then hone to proper clearance. Probably be further ahead cost wise I would think.
MotionMachine
Post by MotionMachine » Thu Jun 07, 2018 8:17 am
I don't know the in's and out's of applying nikasil but it always seems to be done only on individual sleeves, not an entire block. Has the particular engine in this thread ever been divulged?
Post by MadBill » Thu Jun 07, 2018 2:55 pm
I believe one of the issues re applying it direct to an iron block is that variabilities in typical cast surfaces make the process problematic.
nwticerider
Post by nwticerider » Sun Jun 17, 2018 1:18 am
I would be more concerned with the taper and out of round than the extra thou or two of clearance.
Gap the rings correctly, as stated in an earlier post and get that engine humming.
It is unfortunate that somehow they got it that far over but unless the pistons are very short like a dirt bike it will be fine.
I have taken apart engines that were runnning fine with a correct cranking compression that had a wear ridge and measurement that was huge.
groberts101
Post by groberts101 » Sun Jun 17, 2018 11:17 am
I've been there too.. and probably many here have as well. Ridge ream it, rebore it with an upsized piston thinking things will improve a greater amount.. and it only ends up nominally improved over the other "old and worn out" baseline. Sure makes you aware of need for proper testing and analyzing requirements to make the best cost vs gain decisions in the future.
John@RED
Post by John@RED » Sun Jul 08, 2018 3:44 am
So in the end I let that machine shop to sleeve this block, and that's the result:
Am I wrong, or the step in the lower part of the bore (0.5" from the bottom) is likely going to rub off some coating and material from the piston skirt?
