wanted sunnen PLB-100 pilot bushings
NOT ALLOWED: Selling or reselling in a retail manner.
Thundervalley
Post by Thundervalley »
Looking for a std set of pilot bushings for sunnen PLB-100 ones that fit 350 chevy and 454.These were the ones that came standard with the unit.
ProPower engines
Re: wanted sunnen PLB-100 pilot bushings
Post by ProPower engines »
Its cheaper to machine your own bushings then get the sunnen bushings. I have the sunnen ones but as you already know the block tolerances can allow then to be loose in the bores even with the caps snuged and they will make a .001 larger OD for you but that takes forever.
Give Kevin at Taylor Ent. in Iowa a call.I get him to make my custom bushings to the sizes I work with not a predetermined size that don't fit.
He manufacture those bushings as well as other custom replacement tooling for Kwik Way line boring set up's and some BHJ upgraded fixtures.
His stuff is top quality and fits right the 1st time as well as any corrections to the original designs will have the fix includes.
If you want his contact number PM me and I will get it to you
Dave
