Winner Of The Race Engine Challenge
Gregory
Post by Gregory »
Greg Brown, Hammerhead Performance won the Race Engine Challenge with a score of 1634.
Greg Finnican
Promoter
Gregory
Re: Winner Of The Race Engine Challenge
Post by Gregory »
Jack Barna, Valley Performance, finished first in the In-line class with a score of 1549.
Buck Hinkle did make three successful pulls for a score of 1523.
Greg Finnican
Promoter
CamKing
Post by CamKing »
What happened to Randy's engine? It was leading in the inline class when I left. Did it not pass tech ?
Walter R. Malik
Post by Walter R. Malik »
CamKing wrote: Sun Oct 07, 2018 12:55 pm What happened to Randy's engine? It was leading in the inline class when I left. Did it not pass tech ?
They measured the compression ratio to be a tenth to high on one side so, I got tossed.
Not near responsible for the 70 some points difference between the two engines.
It sure would be nice to have a "seasoned" tech inspector there for each operation in order to get the correct calculations because I really think it got messed-up.
Oh, well.
CGT
Post by CGT »
Walter R. Malik wrote: Mon Oct 08, 2018 10:47 am
Oh, well.
How did they check it? Did they go by published data on some components? Or was everything actually checked?
Walter R. Malik
CGT wrote: Mon Oct 08, 2018 10:50 am
Oh, well.
A cc amount of near 2.5cc's got taken into consideration twice because the piston was .012" above the deck at TDC ... when that amount should have been removed from the swept volume only once.
.100" down from TDC is only .088" down from the DECK so the down-fill divider in the formula was bad data.
It's over ... it is what it is. I will improve it and be back next year with a vengeance.
CamKing
Post by CamKing »
Oh, well.
Sorry I left before this happened.
I've been talking to Greg, yesterday and today, working on a plan to make sure this doesn't happen again.
I'm looking for someone in the Charlotte area with a P&G gauge to check CID, and a Whistler to check compression ratio. There should be no need to pull these engines apart.
Walter R. Malik
I agree with the "P&G" and especially the "Whistler"; there should be at least a few in that area however, taking a head off is mainly so the other teams can get a look at what was done in order to make that engine what it is.
I wouldn't want that part to be changed ... but, using the "P&G" and "Whistler" FIRST would certainly be a lot faster.
grandsport51
Post by grandsport51 »
Walter,
Regardless of false measurement
Your Engine still Showed Great!!
Kick Butt next year!!
Dave B.
LIGHT 'EM UP
Warp Speed
Post by Warp Speed »
Walter R. Malik wrote: Mon Oct 08, 2018 11:31 am I agree with the "P&G" and especially the "Whistler"; there should be at least a few in that area however, taking a head off is mainly so the other teams can get a look at what was done in order to make that engine what it is.
Only problem with a P&G and a Whistler gauge, is they aren't very close to accurate at all. Unfortunately, neither was the tech inspector apparantly! Lol
Congrats anyway!
Walter R. Malik
Warp Speed wrote: Mon Oct 08, 2018 11:42 am
Congrats anyway!
A P&G is not perfect but close and I have never witnessed a Whistler to be wrong, unless the data input is wrong or ring blow-by is high. These engines have almost no blow-by at all.
Walter R. Malik
grandsport51 wrote: Mon Oct 08, 2018 11:38 am Walter,
Dave B.
The actual measurements were fine ... just the derived data was off.
It's overwith ... moving ahead is paramount.
Last edited by Walter R. Malik on Mon Oct 08, 2018 12:32 pm, edited 1 time in total.
CamKing
Post by CamKing »
Walter R. Malik wrote: Mon Oct 08, 2018 12:12 pm A P&G is not perfect but close and I have never witnessed a Whistler to be wrong, unless the data input is wrong or ring blow-by is high. These engines have almost no blow-by at all.
From what I was told, the engine needs to be cold for the P&G. My thought is to use it on each engine before their first run, and use that displacement for calculating their score.
randy331
Post by randy331 »
I'd rather see a spec fuel with no comp limit. Let the engine builder decide what they can run on that particular fuel. Isn't that part of engine building ?
That'd do away with this type of problem.
I spent a lot of time making sure our 2017 engine was at, but not over the comp limit. But there's always room for someone else to come up a little different on it.
Anyway good job Walter !
Randy
tenxal
Post by tenxal »
CamKing wrote: Mon Oct 08, 2018 12:32 pmFrom what I was told, the engine needs to be cold for the P&G. My thought is to use it on each engine before their first run, and use that displacement for calculating their score.
When I did P&G'ing at NHRA events, the gauge came with a thermometer and a calibration chart. Used correctly, they are very accurate.
