Your opinion.....ring gap for n/a 434 sbc
rewguy
Post by rewguy »
13 deg. 15-1, race gas, drag race, total seal ap top rings, Napier second. Std. Tension oil ring, vac pump.
Mark O'Neal
Re: Your opinion.....ring gap for n/a 434 sbc
Post by Mark O'Neal »
.018 - .021
Or more.
cjperformance
Post by cjperformance »
Piston material?
Block filler?
Target run temp?
More info.
Craig.
Frankshaft
Post by Frankshaft »
I would set them at .024 and .030 2nd.
rewguy
Post by rewguy »
2618 forged. Probably 175 degrees race temp. No block fill. Darr lil m block.
engineguyBill
Post by engineguyBill »
.0045" to .0055" per inch of cylinder bore for the top ring; .0060" to .0070" for the second ring.
Bill
SAE Member (30 years)
steve316
Post by steve316 »
I would go with mark's recommendations for the top ring and open up the second ring to .025
steve316
Post by steve316 »
Why are you running a standard tension expander with a vacuum pump?
ProPower engines
Post by ProPower engines »
rewguy wrote: Thu Oct 11, 2018 11:05 pm 13 deg. 15-1, race gas, drag race, total seal ap top rings, Napier second. Std. Tension oil ring, vac pump.
Are the pistons gas ported in any way ???
And why a std. oil ring with a vac. pump?? Why no go with a low tension oil ring?? Issues with the combo before??
rewguy
Post by rewguy »
no reason. I just put back exactly what was in there.
induction apprentice
Post by induction apprentice »
Top .027"
Second .030"
af2
Post by af2 »
rewguy wrote: Fri Oct 12, 2018 10:01 pm no reason. I just put back exactly what was in there.
Then run it the way you did.
Why people set them at the closest they will ring butt is beyond me!
GURU is only a name.
In-Tech
Post by In-Tech »
I'm with ya Adam, there isn't enough TIME, at any kind of reasonable racing rpm,for a couple thou extra to make a difference, gap within reason and put extra safety to it if you are worried about having to chase your tune.
Then put a vacuum pump on it and fuggit 'bout it. :lol:
-Carl
