6.0 ls camshaft opinions
JodyB
Post by JodyB »
Hi all!! I have a 2000 chevy 1500 4x4. 4L60 trans with 2500 converter, 3.42 gears, and stock size tires. Probably 5000 pounds or so. Building a 6.0 to replace the 5.3 and looking for all the midrange torque possible with a 6000rpm shift. Trailblazer ss style truck intake, 799 cathedral port heads(similar to ls6 243 heads), 10.3:1 cr, long tube headers, low restriction inlet and ex systems. I'm really leaning towards something in the 200-205 intake, 205-210 ex at 50 to shoot for a 55-5800 peak. Maybe on a 108-110 lsa to get all the midrange torque possible? A rough idle is acceptable, and i have software to tune it. Any thoughts or opinions?
JodyB
Re: 6.0 ls camshaft opinions
Post by JodyB »
Image This is an example of a fellow's full bolt on factory cam ls1 engine then swapped to a ls6 cam
JodyB
Post by JodyB »
# Duration* Valve Lift LSA
Corvette LS1
97-98 12554710 199/207 .472/.479 117
98-99 12560964 199/207 .472/.479 117
2000 12560968 198/209 .500/.500 115.5
01-03 12561721 196/207 .467/.479 116
Corvette LS6 405hp
02-04 12565308 204/218 .555/.551 117.5
Newold1
Post by Newold1 »
Take a look at the Crane #1449551 camshaft. Its a great cam in a 6.0L like you are planning.
Olds455
Post by Olds455 »
JodyB wrote: Sat Dec 08, 2018 4:03 pm Hi all!! I have a 2000 chevy 1500 4x4. 4L60 trans with 2500 converter, 3.42 gears, and stock size tires. Probably 5000 pounds or so. Building a 6.0 to replace the 5.3 and looking for all the midrange torque possible with a 6000rpm shift. Trailblazer ss style truck intake, 799 cathedral port heads(similar to ls6 243 heads), 10.3:1 cr, long tube headers, low restriction inlet and ex systems. I'm really leaning towards something in the 200-205 intake, 205-210 ex at 50 to shoot for a 55-5800 peak. Maybe on a 108-110 lsa to get all the midrange torque possible? A rough idle is acceptable, and i have software to tune it. Any thoughts or opinions?
What's a SS "style" intake? Is that an actual oem truck intake or some aftermarket SS "style" intake like you describe it. If it's a truck intake, it wouldn't be a whatever style intake. Itd be a truck intake. Would it not? Just trying to understand what you're describing. We're not all LS people over here that know exactly what all this refers to.
Keith Morganstein
Post by Keith Morganstein »
I would go a different way. There is NO need for a rough idle to reach your goals (unless you just want a rough idle)
This Jones cam was made for me to have a good idle, strong midrange power and retain good economy.
Jones Cam # HR67312-69312 it’s 212*- 218* @ .050” , 114* LC, .530” lift w 1.7 RR
JodyB
Post by JodyB »
The trailblazer ss intake manifold later became the 2007 up truck intake.
Newold1
Post by Newold1 »
The cam Kieth is recommending is almost identical to the Crane cam I mentioned. Make sure you follow cam companies recommendation on valve springs.
JodyB
Post by JodyB »
Any thoughts on these Cam Motion cams?
Grind # XA202/310-XA206/310-14+4
Duration at .050 - 202/206
Lift with 1.7 - .527/.527
Lobe Separation 114
Intake Centerline 110
Grind # XA206/325-XA210/325-15+5
Duration at .050 - 206/210
Lift with 1.7 - .553/.553
Lobe separation 115
Intake center line 110
Newold1
Post by Newold1 »
Kip at Camotion is a great cam developer and his results in LS engines is substantial.
I have started using his zero lash solid roller designs in some of my street,/strip and racing builds with great results.
As for your question, don't undercam from a duration standpoint that 6.0 of yours looking for more low end grunt. I think the specs for the second choice listed is a better cam for your use and the lsa will keep your EFI happier with a nice idle and mpg better.
JodyB
Post by JodyB »
Thankyou for the advice and experience guys. The ideas pointing me towards a small cam are 5000ish lbs, 3.42 gears, 2500 converter, 6000rpm shift, and the wide gear ratios of a 4l60.
My research of 5.7 and 6.0 ls engines with headers and low restriction inlet&exhaust seems to indicate cams with over 210 at 50 intake duration begin to push the hp peak to 6000-6200ish rpm, sacrificing some useful low rpm torque. Though most are using a fairly retarded 114ish Intake centerline.
JodyB
Post by JodyB »
Results from a bone stock 2004 ls1 gto with a
197/207 .467 .479 116 lsa factory camshaft
Keith Morganstein
[quote=JodyB post_id=784823 time=1544393197 user_id=28868]
[/quote]
Intake is on 110*, I’d expect you will be happy with it. My customers are.
However, it’s easy enough to discuss it with Mike Jones.
Last edited by Keith Morganstein on Sun Dec 09, 2018 6:06 pm, edited 1 time in total.
JodyB
Post by JodyB »
https://ls1tech.com/forums/dynamometer- ... -dyno.html
https://ls1tech.com/forums/dynamometer- ... k-cam.html
These were interesting results from a 5.7 ls1 gto with every possible bolt on, electric water pump, ported Advanced Induction heads, 11:1cr and a stock ls1 camshaft.
JodyB
Post by JodyB »
+1.8 ratio rocker arms
