Real Budget Vortec Engine build
Carnut1
Re: Real Budget Vortec Engine build
Post by Carnut1 »
rebelyell wrote: Wed Mar 13, 2019 4:43 pm Not trying to be funny ... I ask because I don't know and I'm following this build's details as closely as I can
What are meanings of following terms / abbreviations?
SN ?
Randy Valve Job ?
Randy Porting ?
Snotty ?
SN special needs build (thread)
50 degree
Special secret Randy porting
Snotty: high specific output engine for the cubic inch
631-816-4911
9:00am - 9:00pm EST
CGT
Post by CGT »
paulzig wrote: Wed Mar 13, 2019 4:42 pm
CGT wrote: Tue Mar 12, 2019 9:18 am If they were for trying a cam on the dyno, I wanted to do something drastic for the sake of learning.
Why not go the other way?
Like a solid roller, remove the hydraulic element, and go to a much smaller SR lobe as this only peaked at 6000RPM..
Looking through the comp book:
IN: 4871 the XE 224@50 lobe
EX: 1476 the HE 244@50 lobe ... 109 LSA something like that
Well its all hypothetical now since the engine is gone. But, as nice as a SR is for testing it just wouldnt be in the budget for "Dale". And my thought was to see if peak hp rpm could be pushed up with more area....how much and how the curve looked at and around it. I also would like to see how the bottom of the curve stood up to a chunk more duration thrown at it.
levisnteeshirt
Post by levisnteeshirt »
Really impressed ,, saw a 355 with trick flow 210 heads I think , Vic Jr , bullet flat tap 254/262-106 cam , approx 10.5-1 , 750 quick fuel do 504 HP , probably spent a good bit more than what you guys did ,,
steve cowan
Post by steve cowan »
levisnteeshirt wrote: Mon Mar 18, 2019 9:50 am Really impressed ,, saw a 355 with trick flow 210 heads I think , Vic Jr , bullet flat tap 254/262-106 cam , approx 10.5-1 , 750 quick fuel do 504 HP , probably spent a good bit more than what you guys did ,,
good post levis,
the reality is it is tough to get a genuine 500hp out of a pump gas 10.5:1 small block anything,we all know some good fellows on this forum punch way above,and through testing and actually building engines they get the job done and post there results good or bad.
i spend a lot of time at my local track and all i hear is my engine makes 600 plus blah blah and @ 3400 pounds runs mid 11s @118 MPH.OR SO
thats probably 100 hp shy,anyway i should not be raving on,just felt like having a whinge. :roll:
levisnteeshirt
steve cowan wrote: Tue Mar 19, 2019 6:02 am
good post levis,
The engine I mentioned was an underperforming unit in the car ,, I don't know if it was converter , gear , what ,, I have to wonder if it was a intake velocity thing ,, yes it made 500hp on a dyno , no timer on a dyno , just hard to nail down exactly , but if I was a betting man I would say the head was a little big ,, this shop has done other motors that did less of a dyno number and were .50 quicker in the 1/8 in a similar car / set up
steve cowan
levisnteeshirt wrote: Tue Mar 19, 2019 11:19 am
good post levis,
good point,
i actually had a phone conversation with a pretty smart guy from the forum here a couple of weeks ago and shift recovery came up in the conversation,
even for own limited knowledge and experience have gone to smaller heads and smaller cams with surprising time slips,my car is running within a few tenths in the 1/8 mile compared when i had a bigger head/cam and higher rpm application
CGT
Post by CGT »
Stopped by to check on Project Dale. Looks like theyve been having some fun...
steve cowan
I think Dale is waiting patiently,
Wants to help turn the rear tyres in anger :D
CGT
Post by CGT »
[q
steve cowan wrote: Tue Apr 09, 2019 12:53 amtyres
Do tyres hook better than tires Steve??? I was a terror at this kids age(17) with a high 14 second car. But fortunately, Brenden seems a more calm and responsible than I was. It should be a 120mph car in reasonable air.
steve cowan
CGT wrote: Tue Apr 09, 2019 11:04 am [q
C H A D,
you had me second guessing on my spelling lol
Australian spelling - tyres
American spelling - tires
both mean round rubber things that produce white smoke (burnout)
Australian spelling - tires- exhausted,buggered,knackered,f**ked,needs a rest etc
this is hilarious,never in all my years have i noticed this. :D
wilson1970
Post by wilson1970 »
What did you use for carburetor and ignition?
zums
Post by zums »
I thought it was tirez, i know one thing, the kid is goonna need new pantz when he dumps the throttle
Tom
randy331
Post by randy331 »
zums wrote: Tue Apr 09, 2019 8:17 pm I thought it was tirez, i know one thing, the kid is goonna need new pantz when he dumps the throttle
Tom
LOL :lol:
Randy
steve cowan
randy331 wrote: Tue Apr 09, 2019 8:20 pm
Tom
LOL :lol:
Randy
Good one Tom :D
It will be a tough streeter for sure
CGT
Post by CGT »
wilson1970 wrote: Tue Apr 09, 2019 7:56 pm What did you use for carburetor and ignition?
It used a 6AL and a MSD billet on the dyno, Braswell 1.490 x 1.75 carb if I remember right. He has a used digital 6 box for the car and is buying a new carb with similar dimensions for the car.
Would have been nice to have his carb for the dyno.....but I had him get an O² bung added to his header so we can get it tuned up a bit quicker in the car. Not sure what to expect with the new Holley carb.
