New crank cracked?
AC sports
New crank cracked?
Post by AC sports »
Bought a new old stock crankshaft last week for a Fiat twincam.
It arrived with lots of factory wax and a few small areas of surface rust which I polished out. Upon further inspection I find this :
At first I thought maybe a scratch, but given it goes into the fillet radius also, I figure it's a crack.
No one local to x ray, so scrap metal?
Only seen this on used cranks and typically either from oil holes or from fillet radii going out.
BillK
Re: New crank cracked?
Post by BillK »
Where are you located ? No shop in the area that can magnaflux it ?
Post by mag2555 »
It does not look like a crack as it's too jumpy and inconsistent!
enigma57
Post by enigma57 »
Could be a surface scratch. If you test, do a radiograph. Magnaflux test will pick up discontinuities both open to surface and slightly below surface. Dye penetrant will pick up anything open to surface. Neither will tell you with certainty what is going on deeper beneath the surface.
Or you could turn that journal 0.010" (or until line is no longer visible) and then take another look at it. If its OK, turn remainder of journals same amount.
Just a thought,
Harry
Dave Koehler
Post by Dave Koehler »
Left to right? Never seen a straight line crack. That has to be a scratch. Too straight and it appears to hit the high spots of the machining.
Scotty
Post by Scotty »
I have seen lots of forged steel diesel and petrol automotive crankshafts that have cracks like that witch line up with the forging line , its certainly worth giving it a polish with fine emery tape and further inspection. You can get a white background paint and magnetic black particle spray cans for crack testing then you only need 2 strong magnets placed either side of the crack to inspect if you cannot get it magnafluxed.
Note the alignment of the crack with the forging line on this crank and usually they are predominatly found on the underside of the be jnl.
Dave Koehler
Scotty,
Oh yeah, seen those but I think the OPs line looks too straight. Flux will tell of course.
jake197000
Post by jake197000 »
look at it under magnification
AC sports
Post by AC sports »
Under 10x it definitely has the jagged lines of a crack and not the smooth edges of a scratch. It doesn't look too deep so may clean up with a 10' turn.
modok
Post by modok »
looks like a scratch, even if it is a crack, I'd guess that it will not cause any problems, because of where it is.
It is possible for a a crank to crack that way during heat treating.
Mummert
Post by Mummert »
The top doesn't look like a crack. They have very defined skwiggles (if thats a word). The second picture is cracked, but with the small surface cracks around it they may not be that deep. The second crank would probably save with a grind.
Mummert Y-blocks
bigmike
Post by bigmike »
That is a forging void.
MotionMachine
Post by MotionMachine »
bigmike wrote: Thu Apr 11, 2019 4:16 am That is a forging void.
I tend to agree with this. Especially considering it's in line with the forging seam. When I've seen cracks like in the pic Scotty posted, they were caused from heat, just like cracks in the face of a flywheel. I've tried to grind them out but rarely do they go away with a minimal grind. Since the crank is new, it hasn't been subject to any trauma. I think it just didn't clean up completely from the rough forging when it was ground.
Truckedup
Post by Truckedup »
MotionMachine wrote: Thu Apr 11, 2019 8:21 am
If so, is the crank usable for high performance ? Grind it undersize to try and clean it up?
miniv8
Post by miniv8 »
Step one: Bathe the crank in kerosene
Step two: tap it with a hammer while wet
Step three: dry it completely off
Step four: collect a handful of shop dust and cover the crank in it
Step five: tap it with the hammer again until the dust comes off your crank and look for wet spots
Source: YT-video shared on Speedtalk
