REC Seminar content'
bigfoot584
Re: REC Seminar content'
Post by bigfoot584 »
David Vizard wrote: Mon Jun 03, 2019 8:54 pm
Dragsinger wrote: Mon Jun 03, 2019 4:21 pm Is the cam program available for sale without attendance?
Yes,
Go to our web site davidvizardperformanceseminars.com and contact Marvin on:- PHONE : 865-850-0666 or
E-MAIL :- MARVINGVX@GMAIL.COM
Tell him you are an ST memeber and you could be inline for a sizable discount.
DV
I purchased it off the web site, curious about it, wanted to see what it would do, but was
never able to get it to work it has some page pop up where you need to enter a sales order
number then hit done, but nothing happened after that it just sitting on a memory on my
desk now, kinda dissappointed.
PRH
Post by PRH »
I think a better way to illustrate the velocity at lash point would be to start just at the point of lifter rise and measure the lift per degree from that point to a point a few degrees after the lash point........ and compare the curves between the two cams that way.
I’m not a cam lobe designer, but it would seem whichever cam has less change in lift per degree at the lash point and slightly beyond, would be the one with less jerk.
RevTheory
Post by RevTheory »
bigfoot584 wrote: Fri Jun 14, 2019 2:08 pm
Yes,
DV
It's a bit of a struggle getting the guy handling that end of things to take care of business.
David Vizard
Post by David Vizard »
RevTheory wrote: Fri Jun 14, 2019 2:23 pm
Yes,
DV
Rev,
I just PM'ed Bigfoot about sorting this out. I will personally see he gets all up and running as should be the case.
DV
RevTheory
Post by RevTheory »
You ever walk away from the computer regretting hitting the submit button on a thread? Yeah, I just did that.
Back to pushrods, spintrons and REC lectures :D
Stan Weiss
Post by Stan Weiss »
Yes,
DV
If you email me a print screen of the validation screen along with your email address I will email you back the needed UNLOCK CODE.
Stan Weiss <srweiss1@comcast.net>
Stan
GARY C
Post by GARY C »
Yes,
DV
The way these guys are locking these programs down now days makes it hard to activate and or reactivate... I have CI and early version of Pipe Max and can't use them without having to send a code to reactivate.
Stan Weiss
GARY C wrote: Fri Jun 14, 2019 6:09 pm
Yes,
DV
Gary,
I can no say about other programs but TMC (or FLOW or my program CARFOR) if install and activated on you computer doesn't need to be reactivated when a new / updated version is sent.
Stan
GARY C
Post by GARY C »
Stan Weiss wrote: Fri Jun 14, 2019 6:20 pm
Gary,
Stan
Yes the original FLOW program of Davids that you sent still works fine, I don't recall any install trouble (Windows 8.1), just speaking in general of modern programs people are putting out there and the difficulty some may encounter.
EDIT! I will add that all the ones I have dealt with require an unlock code as you have offered which is par for the course and understandable.
Gregory
Post by Gregory »
The Race Engine Challenge and Technical Engine Conference has been expanded and now runs from
Monday September 16th thru Saturday September 21st.
Revised ticket pricing on the web page.
THE STAFF
www.RaceEngineChallenge.com
bigfoot584
Stan Weiss wrote: Fri Jun 14, 2019 4:29 pm
Yes,
DV
Stan
Thanks Stan, it's up and running, DV I won't be calling, Thank for the offer to help.
David Vizard
Bigfoot,
Glad you are up and running. Let us have your thoughts on the program when you are done.
DV
GARY C
Post by GARY C »
justanothermelvin wrote: Sun Jun 16, 2019 2:09 am
Controlled Induction program updates install and run without any code reactivation. Upgrading to another program does require an initial code.
I have had so many updates to fix problems with that program that I no longer know which one to use... I have at least 5 different versions since the original... Don't get me started on that!
bigfoot584
GARY C wrote: Sun Jun 16, 2019 7:10 am
X2, and because of that I just don't feel comfortable with it's outputs.
I have much better experience with Performance Trends EA program
and DV's 128 formula.
GARY C
Post by GARY C »
bigfoot584 wrote: Sun Jun 16, 2019 7:37 am
Yes it seemed that regardless of how complicated the entry got it never gave you a different cam selection and in regards to a SBC you could use DV's 128 or his 90's version of cam masters to end up with the same cam. Now CI want info that most people don't have so that it can give you the same cam you would have got in it's original form???
