GM Rocket block oiling problem
Re: GM Rocket block oiling problem
Are the lifters going too high and just into the roller area causing a huge leak?
I would drain the oil and check for aeration after a short blast.
What is the GPM of the Titan oil pump ? You might need an Accusump. That is a lot of Main and rod clearance. I think the flow of a standard SBC pump is 7 GPM at 3000 rpm.How high are you turning the engine? I am wondering how much flow at 6,7,8000 rpm?
Rewguy, are those Lunati roller lifters the ones you are using ( i assume so) ? Are those identical to the lifters used in the past ? Mark H.
Have you tried priming the engine? I did the same thing more or less using a Dremel tool to groove, once assembled I primed it. Nice, lots of oil (had same issues, would not oil up top until running for a minute with the first set of non grooved lifters, actually burnt up a rocker tip and valve over the season) but after a few seconds you could hear the pump suck air. The is with a Dart Little M and fortunately I had installed .090" restrictors in the front (was wide open in the rear) so I plugged the back lifter gallery oil feeds and ran it. It's not brilliant, 7 quarts in a 6 quart pan and the oil pressure gauge fluctuates between 42 and 50 for the last half of the track. I'll finish off the season then look at the bearings in the off season. I plan on restricting it further for next year, trial and error on the engine stand by plugging the front and adjusting the rear orifices as required.rewguy wrote: ↑Wed Jul 31, 2019 5:14 pm p.s. When the engine first fired it would not oil the rockers.......I added small grooves to the pushrod feed hole to help. About .020 deep, and .025 across. PLENTY of oil then. But I have a very hard time believing that the grooves are the issue with running the pan dry this quickly.
Using Lunati ultra pro which I believe is made by Morel. The bodies I believe are about .001" bigger than Comp and that is what I attribute to the "no oil" issue (at least in my case) I plan to hone another .0005" into the bores as part of a major refresh down the road with new, non grooved, lifters. I had no oil pressure issues before I put in these oiling grooves.
Does your block not have provisions to restrict the lifter gallery feeds?
Drop the pan 1 to 2 inches in the front spin the pump with a drill and watch where the oil is going.
That looks like a Morel lifter with two edge orifice holes. With .0019 lifter to bore clearance, you should have had plenty of oil to the top without modifying the lifters. We run that style lifter with .0013-.0014" clearance and no modifications and get plenty of oil thru the pushrod.
Those grooves you added are massive and it appears you have two per hole. If you ever do another set, have someone surface grind them or mill with a carbide endmill. One .002" deep flat per hole adds a lot of oil and consider doing just one hole per lifter.
I would make a drain hose from the back of the valve covers to the pan
i had same issue with Valvoline VR-1 20W-50 in my hyd roller BBC changed to mobil1 5w-50 and no issues.
I have not tried it without the vacuum pump as my valve covers don't have breather enough provision for adequate breathing
I agree completely......Charliesauto wrote: ↑Thu Aug 01, 2019 11:06 pmThat looks like a Morel lifter with two edge orifice holes. With .0019 lifter to bore clearance, you should have had plenty of oil to the top without modifying the lifters. We run that style lifter with .0013-.0014" clearance and no modifications and get plenty of oil thru the pushrod.
It is the first build for us on this. So they are the only lifters we've tried in it.swampbuggy wrote: ↑Thu Aug 01, 2019 6:32 pm Rewguy, are those Lunati roller lifters the ones you are using ( i assume so) ? Are those identical to the lifters used in the past ? Mark H.
I believe we will try this soon. I plan on restricting the oil to the top first as long as I can figure a way to do so.
I don't know how familiar you are w maxracesoftware......Larry Meaux......But a few years ago he talked about the oil clearance He and his buddy Chris used in their engines......and this is very similar. Even Darin Morgan made a statement along the lines of.....It had been twenty years since he ran less than .003-.0035 on rods OR mains in ANY engine period. This especially is a run "almost right off the trailer", very little warm up time, sportsman style crank.........(no winberg or kellogg) etc. The cheaper cranks tend to move a bit more than the big dollar stuff..... And we've run similar clearances for years and bearings always look new after a year of thrashing.Warp Speed wrote: ↑Thu Aug 01, 2019 2:06 pmIt is for straight 50w!
- af2
Yep! I am going to be in the same boat in a couple weeks when I start assembling the Rodec block that has the same oiling as yours. I will plug the rear valley and plug the front galley with .040" holes for the cam. I hope it is enough to oil the upstairs. I was told by a few friends that ran them to do it this way,, We will see. Just putting it out there from another .003" drag racer that my last engine ran 15 years seeing 10,000 more than once and 8500 at the shift. And yes the burnout was with the engine temp at 100*rewguy wrote: ↑Fri Aug 02, 2019 11:02 amI don't know how familiar you are w maxracesoftware......Larry Meaux......But a few years ago he talked about the oil clearance He and his buddy Chris used in their engines......and this is very similar. Even Darin Morgan made a statement along the lines of.....It had been twenty years since he ran less than .003-.0035 on rods OR mains in ANY engine period. This especially is a run "almost right off the trailer", very little warm up time, sportsman style crank.........(no winberg or kellogg) etc. The cheaper cranks tend to move a bit more than the big dollar stuff..... And we've run similar clearances for years and bearings always look new after a year of thrashing.
GURU is only a name.
