Electric Motor efficiency and regen capability.
Anything to do with the electric or hybrid world
emsvitil
Post by emsvitil »
Three questions on Electric Motor efficiency and regen capability.
1. What is the typical efficiency of the electric motor? You put 100kW of energy in, how much is actually moving the car? (95kW 95% ??)
2. Same question on regen. 100kW of braking, how much makes it back to the battery? (95kW 95% ??)
3. Can it absorb the same amount of energy as it puts out? Does 100kW motor have 100kW of braking ability? Or is it less or more (50kW,150kW)
Just curious
Ed
underhead valve
Re: Electric Motor efficiency and regen capability.
Post by underhead valve »
I don't know how much loss ,but some of the older electric cars I worked on used motor cooling for cabin heating
Rick!
Post by Rick! »
emsvitil wrote: Wed Jul 24, 2019 7:55 pm Three questions on Electric Motor efficiency and regen capability.
https://www.engineeringtoolbox.com/elec ... d_655.html
You only get to use one axle set for regeneration on a typical EV so in terms of kinetic energy recovery, it is around 55%. If you only look at kW out vs kW in, you recover around 25%. https://www.proev.com/LLPgs/LLei0005.htm
Google is your friend.
Just curious
gmrocket
Post by gmrocket »
I remember seeing a drag test of a tesla where they did all the math and it ran something like mid 12's which is pretty impressive for a 100k car (🤣😅😉) and figured out with its regen breaking it could do that EXACT same time for about 170 runs?
Correct me if I'm wrong
