Eagle used to make one. Not sure if they still doSteve.k wrote: ↑Tue Aug 27, 2019 2:00 pmCraig do you know anyone else that makes a crank with 4.25 stroke and the 3" main? Most I've seen run the cleveland main.cjperformance wrote: ↑Tue Aug 27, 2019 1:50 am A pass on a crack test of course doenst mean a oart wont develop a crack later on in use but at least you know you are starting with a good piece and have the peace of mind that you at least tried to make sure everything was good.
Crank failure
Re: Crank failure
Re: Crank failure
Steve, as Lance mentioned Eagle did make one in 4.250", the last one . As far as im aware 4.170" is it thses days.Steve.k wrote: ↑Tue Aug 27, 2019 2:00 pmCraig do you know anyone else that makes a crank with 4.25 stroke and the 3" main? Most I've seen run the cleveland main.cjperformance wrote: ↑Tue Aug 27, 2019 1:50 am A pass on a crack test of course doenst mean a oart wont develop a crack later on in use but at least you know you are starting with a good piece and have the peace of mind that you at least tried to make sure everything was good.
Which does make for a WAY easier clearance job compared to 4.250" !
Craig.
Re: Crank failure
You might want to check with Tim Meyers website I’m sure he has a 4.250 crank just not sure if it’s 3.00 mains.
- midnightbluS10
Re: Crank failure
Probe makes/made a 4.250 stroke x 3.000 main crank
https://www.coasthigh.com/Probe-4340-Cr ... -14672.htm
JC -
Re: Crank failure
3" on main 2" on jornal.
Re: Crank failure
Not much journal overlap there!
Re: Crank failure
Yes Bill, very scary looking ammount of material on these cranks in this area!
Craig.
Re: Crank failure
Do you think the cleveland journal size would be better?When u think of a 460 crank with same kinda stroke theres alot more beef.Im not sure why they went 2.0. This one that broke is cleveland size.cjperformance wrote: ↑Wed Aug 28, 2019 12:45 amYes Bill, very scary looking ammount of material on these cranks in this area!
Re: Crank failure
Certainly a lot more than a "Mountain Motor" Pro Stock crankshaft having a 5.750" stroke with an even smaller main.
Those throw arms are not thinned out and the lightening hole is not so large like these cranks, though.
The big engines made a whole lot more torque and horsepower, too.
Most people don't think of it this way but, engine bearings are "consumables" to be replaced often, if need be.
Re: Crank failure
Broke her off the rest of way. Some interesting lines.
Re: Crank failure
Couple more.
Re: Crank failure
Kind of just like my v-6
Re: Crank failure
Sure looks like fatigue to me - which makes X2 on the damper not doing its job. Not tuned for the combination.
