blown olds
rocketracer380
blown olds
Post by rocketracer380 »
olds 350 with 144 blower
travis
Re: blown olds
Post by travis »
rocketracer380 wrote: Fri Aug 30, 2019 1:06 am olds 350 with 144 blower
Is that a question, or a statement? :?
Re: blown olds
Post by mag2555 »
Might this be the answer to your bazaar criptic post ,You'll not get more then about a extra 125 hp ( some 5 to 6 psi of boost) out of that blower if that covers your needs?
gmrocket
Re: blown olds
Post by gmrocket »
Here I'll finish it for you,,,KABOOM!
dfarr67
Re: blown olds
Post by dfarr67 »
Thanks, I needed that this morning ;)
Re: blown olds
Are you interested in doing that? .....or?
Re: blown olds
Post by mag2555 »
Can someone loan me a Rosetta Stone for this string of post please or am I missing the fact that the motor has met its demise?
rocketracer380
Re: blown olds
has anybody done it i have an offehauser dual quad intake i can modify
Dave Koehler
Re: blown olds
Post by Dave Koehler »
I so want to say...get a real blower. Ok. I did it. I feel cleansed now.
It has been done and I suspect Dyer Blowers has the answer.
PS, there are punctuation and upper case keys on your phone.
Re: blown olds
If you do not already own the 144 blower start with a bigger better blower. X2 if you want more than 450 HP.
Re: blown olds
If I had a Olds 350 sb and the Offy dual quad manifold for that and wanted to supercharge it I'd use a TorqStorm blower and use 2 edelbrock 750 cfm carbs .
Carbs can be in a carb box.
Best street strip results if the engine has a low compression ratio.
rocketracer380
Re: blown olds
Is 550hp attainable with the Weiand 142 on a 358 with heads and blower cam
Re: blown olds
Yup bolt the blower onto a 560 HP 358.
You'll get 550 HP.
Seriously a 177 Weiand or the 192 billet TBS blower both
Achieve that power level and more on a 358 very nicely.
The 142-144 blower is going to peak out about 480 HP on a high cr high blower drive ratio, maxed out 358.
Methanol or water injection.
It is very good in the 450-460 HP range.
Dave Koehler
Re: blown olds
Ok, this has to be a street machine.
Consider this..a boosted engine that makes 400 HP on the street can kill you.
How much over that is really useful in a traction limited application?
Any supercharged engine is a blast.
My point is do what you want regardless of what HP it may or may not make here on the internet.
If there is no dyno in your town it can be rated at whatever HP you choose. :wink:
