Engine pro
6 cylinder puller
Engine pro
Post by 6 cylinder puller »
If I buy this program and I end up changing laptops will I still be able to use it on the other laptop or will I have to repurchase it again ?
Re: Engine pro
Post by mag2555 »
As long as the hard drive in your current lap top is alive then yes, you can export it to another lap top.
If your current lap to hard drive ever dies on you then you will loose everything on it that is not backed up by a cloud service or on a CD of yours.
maxracesoftware
Re: Engine pro
Post by maxracesoftware »
6 cylinder puller wrote: Wed Sep 11, 2019 11:29 am If I buy this program and I end up changing laptops will I still be able to use it on the other laptop or will I have to repurchase it again ?
for 1 Speed-Talk 6 Apps Bundle purchase @ $99.00 USD , that 1 License allows you to install Speed-Talk 6 Apps Bundle on up to 3 of your Computers
so if you have a Hard Drive or Computer crash or Windows Upgrade or weird Update
you can use up any of the 3 to receive a new UnLock Code.
So you have 3 times you can Register + receive new UnLock Code for all 6 Apps
after the 3 times are used up .. you will need to purchase Speed-Talk 6 Apps Bundle once again .
come back to this Link to Download + Install + Register Speed-Talk 6 Apps Bundle :
viewtopic.php?f=12&t=58004
or re-Purchase Speed-Talk 6 Apps Bundle , if you already used up all 3 times of your 1 License
MaxRace Software
GARY C
Re: Engine pro
Post by GARY C »
Could it be put on an external hard drive to prevent this or would the computer change still effect it?
maxracesoftware
Re: Engine pro
GARY C wrote: Wed Sep 11, 2019 1:10 pm Could it be put on an external hard drive to prevent this or would the computer change still effect it?
Yes it could .
you would always need to re-Register each time to get the correct UnLock Code
MaxRace Software
