Bench Data
Re: Bench Data
Be interesting to test-glue in a turning vane down the centerline. In the stock elbows of a 1988 Firebird system I tested, they added ~ 4% each.
Outlaw383
Re: Bench Data
Post by Outlaw383 »
Chad you stated those were too fast, what fps would you prefer to see in that area of the floor on a head that size ?
SpeierRacingHeads
Re: Bench Data
Post by SpeierRacingHeads »
Outlaw383 wrote: Mon Sep 16, 2019 10:32 pm Chad you stated those were too fast, what fps would you prefer to see in that area of the floor on a head that size ?
Not sure I care as long as it's the same across and the SSR can handle it with shape or volume.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Re: Bench Data
Started bench work. Baseline.
Flow test with just head
Middle with elbow/TB
Bottom with Carb
Speier Racing Heads
Chad Speier
785-623-0963
Carnut1
Re: Bench Data
Post by Carnut1 »
If anyone can get that air to bend around it would be Chad. I like the plenum mods.
631-816-4911
9:00am - 9:00pm EST
Re: Bench Data
OK, I spent way too much time trying to figure out in the last pic how what looked like chunks of foam rubber stuffed in the runners was really some sophisticated epoxy fill job. It finally clicked that it was foam, plugging the runners that were not being flowed. #-o :oops:
FC-Pilot
Re: Bench Data
Post by FC-Pilot »
MadBill wrote: Thu Oct 03, 2019 5:16 pm OK, I spent way too much time trying to figure out in the last pic how what looked like chunks of foam rubber stuffed in the runners was really some sophisticated epoxy fill job. It finally clicked that it was foam, plugging the runners that were not being flowed. #-o :oops:
On my Ipad I thought he filled the floor of all but one runner. It was a good thing I did not mention anything until I saw it on a full size computer screen. Yep, just foam. LOL
GARY C
Re: Bench Data
Post by GARY C »
FC-Pilot wrote: Thu Oct 03, 2019 5:32 pm
I am not going to admit I thought the epoxy thing also.
SpeierRacingHeads
Re: Bench Data
Foam out of Ferrea boxes! :)
Simple and easy.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Re: Bench Data
I think it's golden. 6% loss to the front runner through the elbow/TB.
Speier Racing Heads
Chad Speier
785-623-0963
Carnut1
Re: Bench Data
Post by Carnut1 »
I think that is excellent that you only lost 6% on the front. I am interested in the difference flow wise from front to back on the manifold. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Elroy
Re: Bench Data
Post by Elroy »
Good flow// Excuse me if this has already been said////what made you decide to change to a different head casting?////Was the first set coming up short of flow goals?
SpeierRacingHeads
Re: Bench Data
Elroy wrote: Fri Oct 04, 2019 2:49 pm Good flow// Excuse me if this has already been said////what made you decide to change to a different head casting?////Was the first set coming up short of flow goals?
No, I just wanted to use my CNC 205cc head.
Basically I built a 13-1 (4.165x3.48) drag engine (VP113) with the same heads and a 260/268 w/.680 lift and I want to see what this does (same bore/stroke) on the same dyno with 11-1 (91 octane) and a 231/236 w/.580 lift.
Just trying to learn something!
Speier Racing Heads
Chad Speier
785-623-0963
Elroy
Re: Bench Data
Post by Elroy »
OK good go then.////////should have more than enough flow for the goal//should be easy to get there.
SpeierRacingHeads
Re: Bench Data
Elroy wrote: Fri Oct 04, 2019 3:13 pm OK good go then.////////should have more than enough flow for the goal//should be easy to get there.
I agree. I put LS 8mm valves in these heads and using a small dual roller spring.
I will need to dyno with a carb, which just saves the injector harness grief.
I will chassis dyno it, so I will have all the data I need.. I hope.
Speier Racing Heads
Chad Speier
785-623-0963
