406 sbc rotating assy
Has anyone had any dealings with Skip White on buying a rotating assy? I'm wanting to build a 406 for my next project, I found a really nice 2 bolt main 400 low mileage block and want to build a pretty stout street engine. It'll be internally balanced and they stated for a $125 upgrade they will do the 'race balance' on the assy. It has a Scay crank, I beam rods, and Wiseco pistons. It won't be spun much over 6000 so I'd think the kit can handle that. Also, the old tale about drilling steam holes in the heads isn't needed on a street motor, is it?
Re: 406 sbc rotating assy
I always thought it was the "street" type applications of the 400 that needed the steam holes, as a more race type of engine had higher R.P.M s with it's associated higher water pump speeds and water flow that helped push any air bubbles or steam pockets on down the road so to speak.
What a crock. For a certain price they will do a half ass job and for another $125 they will do it better. Notice I said "better" not right.
A company that does it that way is most likely not capable of doing it right.
My experience tells me if I don't know whether I really need expensive parts then don't buy them. I don't know why you need to buy from SW? Summit will price match anyone and a few vendors can beat Summit or Jegs prices (Speedway motors, Northern Auto Parts, CNC-Motorsports).
Good luck and make fun.
74 corvette: 350 4 speed
94 Z28: Gen II 350 auto
my own opinion is that if you are going to have it balanced, have a local guy actually balance it vs. paying a vendor who may or may not do anything.
What is the difference between a race balance vs a normal balance? Either its balanced or not right?
Most likely they have package deals where their rod and piston are close to the crank bob weight, the $125 is to actually put it on a machine and balance it.
my only rule of thumb with 400's when doing a rebuild is to go .020 instead of .030. They have thinner cylinder walls in my experience and .020 is a better starting point if pistons are available.
Brian
Brian
- Dave Koehler
Most likely this is it.
Pretty common practice with the "kit" sellers.
I also say have it done locally.
From time to time I get to straighten out some of the balance messes this practice leaves.
Let's just say I have had more than one good deal "balanced rotating assemblies" that zero material had been removed or added.
This is pretty much an impossible scenario when you have parts from here, there and way over there and all pieces are sold on the low bidder plan.
They are betting on averages working out and that phone call doesn't happen.
At 125 bucks (not realistic) I guarantee they are not going to fine tune the pistons and rods.
I also bet that they have a bobweight already made up, betting the average weight of the rods and pistons are the same weights as the ones they measured 5 yrs ago.
https://www.summitracing.com/search/dep ... =Ascending. Everything I have heard about Skip White orders is there is always a problem.
They state that they balance every rotating assembly on their CWT 5500 balancers within 2 grams for no extra charge and include the balance sheet (they have 3 CWT 5500 balancers so it seems reasonable that despite their huge volume that they're probably actually balancing them, IMHO).
With their "Race Balance", they weight match the pistons and rods to within 2 /10ths of a gram or less and then do the final balance within 1 gram.
Sounds like standard balance is just balance everything as-is to within 2 grams on the balance machine; race balance involves weight matching pistons and rods before balancing to within 1 gram. (Does that $125 get you anything of value for a <6,000 RPM street engine, is a different question...)
- Dave Koehler
It does appear they are making an effort.
I've heard of a few people buying from him and having good luck but there is also White performance and Machine, or something like that so I don't really know which one they are talking about. I was going to let my machine shop balance it and after talking to him he doesn't think to much of Scat. I'll just have him get me an Eagle assy, that's what I had in the 434 I had. As far as expensive parts, since I don't have nothing but a block I figure a cast crank with I beam rods and a good set of forged pistons isn't exactly going over board. By the time you find a stk crank, have it redone and do a set of stk rods, I'd just as soon pay a little bit more and do it right.
Thats good to see.
