049 oval port on 396
cpmotors
Re: 049 oval port on 396
Post by cpmotors »
tenxal wrote: Mon Sep 30, 2019 7:40 am
gmrocket wrote: Sun Sep 29, 2019 4:21 pm Dont worry about the valve shrouding on the cyl wall...very little flow goes that away,,its majority biased to the center of the cyl along the common wall of the port. You do not need a bigger exh valve than you have..its big enough.
Agree 100%.
X3
The 2.19 is worth power, the 1.72 can handle more than most people give it credit for ( assuming you are doing the proper sizing and shaping of the SSR and throat area for both valves)
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills since 2008
But both the new 2.14" in and the 1.84" ex then allows the porting meat to create the valve job and bowl throat contour you want.. 396 friendly.
tenxal
Post by tenxal »
A little back side work on the 2.07's and you'll be in good shape. The 1.72's will be fine as is. Take a look at what the rules restricted engines that have to use stock valve sizes and no porting make for power (think NHRA Stock Eliminator).
And the whole bore notching thing is more urban legend than anything. :wink:
TLK396
Post by TLK396 »
Thanks for all the input. I think I will stick with the small valves for the 396. If I build a larger street motor later I will definitely up the valve size. It would be interesting to flow these heads with a small bore fixture on the flow bench, say 4.125 and compare numbers with a larger bore fixture 4.350, with both the small and large valves. Thanks again to everyone's input.
You're on the right track.. The best thing to do for serious power on a 396 is upgrade to a bigger 454-468-496 based engine.
1980RS
Post by 1980RS »
TLK396 wrote: Tue Oct 01, 2019 6:06 pm Thanks for all the input. I think I will stick with the small valves for the 396. If I build a larger street motor later I will definitely up the valve size. It would be interesting to flow these heads with a small bore fixture on the flow bench, say 4.125 and compare numbers with a larger bore fixture 4.350, with both the small and large valves. Thanks again to everyone's input.
You are going to like the way the 049 heads work on the 396. I did it back in the late 80's and the car was a lot quicker and faster with the change just make sure you do the best valve job you can afford.
levisnteeshirt
Post by levisnteeshirt »
What piston gave you 10.5-1 with that huge chamber
TLK396
Post by TLK396 »
I have a 396/375 style piston with a 39cc dome, at .008 in the hole with a .018 compressed steel shim head gasket. Should be in the ballpark +/-.
tenxal
Post by tenxal »
TLK396 wrote: Wed Oct 02, 2019 2:41 pm I have a 396/375 style piston with a 39cc dome, at .008 in the hole with a .018 compressed steel shim head gasket.
Pretty tight on the total deck.....
TLK396
Post by TLK396 »
Yes, probably should go with a composite head gasket and sacrifice a little compression in this case.
