engine masters live feed?
Re: engine masters live feed?
Walter R. Malik wrote: Sun Oct 06, 2019 6:41 pm 1. Blair Patrick ... FE Ford ...2511
2. Geoff Mummert ... S.B. Ford ... 2504
3. Jon Kaase ... B.B. Chevy ... 2448
4. Clark Hinkle ... B.B. Chevy ... 2411
5. Adney Brown ... S.B. Chevy ... 2405
6. Ted Eaton ... Y Block Ford ... 2358
7. Chris Pelczar ... S.B. Chevy ... 2321
8. Barry Robotnick ... FE Ford ... 2285
9. Daniel Boshears ... B.B. Ford 385 ... 2282
10. Jamie Wells ... S.B. Chevy ... 2254
11. David Molnar ... Studebaker ... 2182
12. Robert Peters ... S.B. Chevy ... 2065
13. Michael Semchee ... Pontiac ... 2061
Thanks, Walter. Good thing I wasn't handicapping this like a horse race; I'd lost big bucks. Who'da thunk a Ford FE would win it and Kaase's BBC would be behind the FE and a SBF? And there's a BBF 385 scoring lower than a Y-block and two FEs. And what's with not a single BBM or SBM competing? No Olds, Buick or Cads? The Buick guys are always claiming "stock for stock, the Buick can run with any of them."
Walter R. Malik
Post by Walter R. Malik »
PackardV8 wrote: Mon Oct 07, 2019 10:20 am
Personally, I think they should do something like this class again with O.E.M. heads but, allow switching years on different engine sizes, like most backyard enthusiasts would do. (Even offset ground cranks and such).
Walter R. Malik
bob460 wrote: Sun Oct 06, 2019 7:41 pm What was the issue with Kaase's engine?
There were no issues that anyone could see ... simply not a high enough score.
bob460
Post by bob460 »
Walter R. Malik wrote: Mon Oct 07, 2019 11:44 am
It said on the hotrod site he was down 60-70hp down from pre contest testing.........just curious if something went a miss.
I like those Jesel rockers he had on the BBC.......also expensive!
cjperformance
Post by cjperformance »
Walter R. Malik wrote: Mon Oct 07, 2019 10:56 am
That immediately makes me think ford 400C with 4V iron heads.
Craig.
bob460
Post by bob460 »
cjperformance wrote: Mon Oct 07, 2019 10:42 pm
/quote]
Craig did you see the 408 4v pump gas build by Jason Mansweto?
gmrocket
Post by gmrocket »
I wonder if any Buicks entered but didn't get picked? I know an Olds did
Guess it's more interesting to have 5 fords and 6 chevies.
cjperformance
bob460 wrote: Mon Oct 07, 2019 11:12 pm
Hey Bob, no i havnt, do you have a link. Was it a typical stroker 351 or a 400 block? Im guessing stroker?
Craig.
bob460
Post by bob460 »
[/quote][/quote]
Using a factory 2 bolt pillow clevo block with factory cast iron heads,flat tappet cam just made an impressive 603 ft lbs and 759 hp on pump gas
PRH
Post by PRH »
Anyone have the peak tq/hp numbers for all the entries?
BradH
Post by BradH »
Walter R. Malik wrote: Sun Oct 06, 2019 10:31 am
Other Entries:
Adney Brown = "perfcrank"
Chris Pelczar = "czar racing"
Jesse Robinson = "RAMM"
Team members were many from here.
Did Jesse R (RAMM) show up? I know he was planning a BB Mopar, but don't know if he participated. Doesn't look like it from the results posted here...
1989TransAm
Post by 1989TransAm »
bob460 wrote: Tue Oct 08, 2019 8:24 am
[/quote]
Using a factory 2 bolt pillow clevo block with factory cast iron heads,flat tappet cam just made an impressive 603 ft lbs and 759 hp on pump gas.
[/quote]
I have to agree. Those are impressive numbers.
Steve.k
Post by Steve.k »
1989TransAm wrote: Tue Oct 08, 2019 1:07 pm
[/quote]
[/quote]
Very impressive to say least. The early pro stock guys like Glidden were making this amount of hp. If he did this with no eh plate and pump gas thats very impressive.
Steve.k
Post by Steve.k »
Walter do you know what heads the 289 of second place were using?im thinking the screw in stud hi perf version. Wasn't much to choose from.
BILL-C
Post by BILL-C »
Steve.k wrote: Tue Oct 08, 2019 2:30 pm [quote="Walter R. Malik" post_id=830132 time=<a href="tel:1570463079">1570463079</a> user_id=17962]
[quote=bob460 post_id=830050 time=<a href="tel:1570405283">1570405283</a> user_id=31874]
[/quote]
[/quote]
Geoff Mummert used a set of 1965 289 base model 2v heads with a very well refined cnc porting program run on them.
Carlquist Competition Engines
