LS3 Carbed build
n2xlr8n
Re: LS3 Carbed build
Post by n2xlr8n »
CGT wrote: Tue Sep 24, 2019 2:13 pm
n2xlr8n wrote: Tue Sep 24, 2019 1:25 pm I read fairly well and still can't make sense of it.
ah hah you got me :lol:
:wink:
CGT
Post by CGT »
Off to the dyno
GARY C
Post by GARY C »
CGT wrote: Thu Oct 17, 2019 11:34 amOff to the dyno
=D>
rewguy
Post by rewguy »
any results yet?
CGT
Post by CGT »
rewguy wrote: Fri Oct 18, 2019 2:19 pm any results yet?
I put it on last night, got it all hooked up, fired it, loaded it some...that's about all so far. I will be pulling it tomorrow and maybe into next week depending on how well it goes or who else may need to get on the dyno.
We will see.
randy331
Post by randy331 »
Maybe it needs a bigger carb ?? :D
Randy
steve316
Post by steve316 »
Like a 1350?
randy331
Post by randy331 »
Well ? Anyone wanta take a guess ??
Randy
GARY C
Post by GARY C »
randy331 wrote: Sat Oct 19, 2019 1:37 pm Well ? Anyone wanta take a guess ??
Randy
A million 9? :D
Not sure where he ended up on total combination but I am guessing more than 600 hp.
steve cowan
Post by steve cowan »
Randy
after seeing that stout 408 you did Randy with less compression but Chad has less cubes.
uneducated guess by myself
546 ft/lbs
675 hp @ 6500 rpm
nice build Chad,best of luck on the dyno :D
202ci EH
Post by 202ci EH »
2 hp / ci :D
and peaking 7400 ish
steve cowan
202ci EH wrote: Sat Oct 19, 2019 4:38 pm 2 hp / ci :D
that would be impressive and more than likely possible =D>
randy331
Post by randy331 »
steve cowan wrote: Sat Oct 19, 2019 4:11 pm
Randy
546 ft/lbs
675 hp @ 6500 rpm
Your TQ guess is very close. :)
Randy
steve cowan
1.44-1.47ft/lbs per cube very impressive
as far as peak hp goes not sure where the engine rpm peak would be with that compression and cam.
going to be a bad ass bracket engine either way :D
paulzig
Post by paulzig »
630@6600RPM HP
550@5100RPM TQ
