BBC tunnel ram
BBC tunnel ram
have you dyno tested the Edelbrock #7085 tunnel ram against any other tunnel rams ? I'm using the old Weiand #1985 rectangle port and i read somewhere that Edelbrock claims their new version (made in 2013) #7085 is worth 40 - 50 hp over other t-rams (didn't say which ones). This is all pretty vague so i thought i'd ask the speed talk world. One thing i don't like about the 7085 is it only has a top for dominators. I'm liking my 4150 base 750 carbs even though i would like to try bigger carbs. Maybe 850 or 950 but not ready to make the jump to dominators. I'd have to use adapters or build my own top to run 4150 carbs on the 7085 edelbrock.
Brian
Edit : they claim it made 47 hp over the old victor 2-R and 10 hp over the competition. So i guess it depends which "competition" intakes they were talking about.
Brian
Re: BBC tunnel ram
It depends on your application.
Take a look at the Profiler manifold.
Re: BBC tunnel ram
If you think that your carbs are too small try adding plenum volume and carb height.
( carb spacers) You could also build your own custom plenum for your current Weiand tunnel ram.
Re: BBC tunnel ram
Joe Sherman was a expert at this stuff.. With the big full race tunnel rams he really spin the engines up high to get the power gain. Not sure you want to go there. Takes top parts and maintenance to go there.
Re: BBC tunnel ram
I used one on my 565bbc it made 1118hp@7500rpm
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
918-520-3480
www.wengines.com
Re: BBC tunnel ram
Not yet still finishing it. Driveshaft should be here today. Hopefully in March.Old School wrote: ↑Wed Oct 30, 2019 10:01 amDo you have any et -mph on the on the car with the 565? Very nice engine.
Eric Weingartner
918-520-3480
www.wengines.com
918-520-3480
www.wengines.com
Re: BBC tunnel ram
ThanksWeingartnerRacing wrote: ↑Wed Oct 30, 2019 10:06 amNot yet still finishing it. Driveshaft should be here today. Hopefully in March.Old School wrote: ↑Wed Oct 30, 2019 10:01 amDo you have any et -mph on the on the car with the 565? Very nice engine.
Re: BBC tunnel ram
As far as cast tunnel rams are concerned, I have had excellent results with the Dart product.
Bill
SAE Member (30 years)
Re: BBC tunnel ram
all other things being equal, what does adding plenum volume to the intake manifold do for an engine ?
Brian
Brian
Re: BBC tunnel ram
A larger plenum will slow the air draw speed on each carb venturi. It will tend to dampen induction pulse force both coming and going . Each cylinders intake port has a larger volume of air/fuel to draw from on each intake stroke.
sort of like the action of a shock absorber dampening a spring. Sort of like a condenser's effect action on a AC electrical circuit.
The engine can breathe deeper at high rpm if the carbs are on the small side relative to cid- power demand.
A wider plenum cross section has a slightly diffrrent effect
than a taller plenum cross section does. (Carb height above runner entries.)
Plan on carb re jetting (most likely bigger main jets if plenum volume is added.
