Free - hi-tech 5-75 hp dyno
Moderator: David Vizard
David Vizard
Post by David Vizard »
I asked myself if this post should be in the 'wanted' or 'for sale' department. I figured I cannot possibly be profiting from this because I am, after all, giving it away so that is why you are seeing it here. That said, I am sure some naysayers will conclude that I have some personal agenda here and that giving this dyno away will net me some unforeseen profit.
Anyway, here is the grife on this dyno.
I built this dyno back in the late 1990’s to test pistons and valves that would, if successful, be used in Cosworth’s F1 engines.
Because of the nature of the test parts involved the amount of extra power/torque was expected to be quite small and so the dyno had to be a) ultra-repeatable and b) accurate. Having had past experience designing and building ultra-precision dyno’s I knew going in that a conventional absorption brake was not going to cut it. For accuracy and repeatability, I chose to go with an inertial dyno. I used what, at the time, was a novel concept that allowed the dyno to not only show whatever output at any given acceleration rate i.e. 200 rpm or 500 rpm or even an oddball 334 rpm per second but also steady state output. The software that I used, done for me by my trusted friend Bill Anderson, could get all or any accelerated output rates from just one pull.
The dedicated test engine (comes with the dyno) was basically a Briggs & Stratton side valve junior dragster unit although I have to say that not much, if any, original B&S parts were used. Essentially this test unit, with a 12,000 rpm red-line, was used as the valve train was capable of a valve motion that was close enough to that of the Cosworth F1 engines to prove (or otherwise) the newly designed parts. Also it was much more convenient to work with than a single cylinder from the F1 engine.
The dyno itself is capable of repeating within less than 0.01 of a lbs/ft. The big problem was making the test engine repeatable. To this end I made an oil cooled cylinder head so a copious quantity of oil was pumped through the head and into the engine sump. From here it was drawn out and passed though a large, thermostatically controlled, radiator with a big cooling fan. This move allowed the control of pan and head temps to within 2 degrees F of the target temp. With this cooling plus a selected oil and a gas brew we came up with accuracy and repeatability that was nothing short of outstanding.
As it stands the dyno will need a cosmetic rebuild to bring it to its original visual condition.
Also, the software that Bill wrote is nowhere to be found but Keven Gertgen at Performance Trends has a program that will work with this dyno.
BTW the dyno is sensitive enough to deliver in-cylinder pressure results without any in-cylinder pressure transducers.
So I am willing to let both the test engine and the dyno go to a good cause. Who ever gets it will need to organize shipping from APT in Riverside CA.
I would like to see this go to a school where it can get the maximum of use for the maximum of people.
If you are interested in giving a good home for this dyno just post here with why you would like it and we will see who has/can make the best claim.
The photo below is as the dyno was a few weeks back.
GARY C
Re: Free - hi-tech 5-75 hp dyno
Post by GARY C »
If you know anyone with SEMA, their High School program may be a good home for it.
https://www.sema.org/sema-enews/2019/47 ... kkqQ9WUnFg
David Vizard
I forgot to say that with an increase in flywheel size the dyno could be modified to record up to about 250 HP.
I also omitted to mention that it needs no cooling tower or water tank. You can run this in the middle of a car park with no connections - or in your driveway - neighbors permitting!
Right now it is perfect for junior dragster motor testing.
DV
David Vizard
Another thought occurs to me. This dyno is a good prototype for a college or school dyno as it is cheap and easy to build even by a relatively small shop and needs no dyno cell. A working one could go out the door for as little as $5500 ready to run!
DV
Racer71
Post by Racer71 »
How would it do with 600cc bike motor? I build some for dirt track racing, would be nice to compare cyl head work and coatings etc.
David Vizard
Racer71 wrote: Tue Dec 03, 2019 8:26 pm How would it do with 600cc bike motor? I build some for dirt track racing, would be nice to compare cyl head work and coatings etc.
Flywheel enlargement would be required but nothing too difficult to do.
DV
mekilljoydammit
Post by mekilljoydammit »
OK, so what is this novel concept that allows steady state or constant ramp speed on an inertial dyno? That's an interesting detail.
David Vizard
mekilljoydammit wrote: Wed Dec 04, 2019 8:32 am OK, so what is this novel concept that allows steady state or constant ramp speed on an inertial dyno? That's an interesting detail.
And I thought no-one was going to ask.
Oh and BTW it was stated by a high up in a well known dyno company that super accurate steady state figures from an inertial dyno were impossible. If I had only heard that before I did it! Professor Blair also thought at one time it was impossible until I explained to him how to do it.
Before I spill the beans I want to see if any one else can come up with a solution.
williamsmotowerx
Post by williamsmotowerx »
Tried sending you an email. This is perfect for my size engines.
Tuner
Post by Tuner »
David Vizard wrote: Wed Dec 04, 2019 12:00 pm
Eddy current brake with the starter/generator on the left.
mekilljoydammit
I'm really curious because all the methods I can readily think of are cheating... some sort of non-inertial load.
I definitely don't want to deprive someone who could use this exact thing by throwing my hat in the ring, but given the capabilities of the data acquisition I have at my disposal, I think I could get some interesting work done with something like this.
BLSTIC
Post by BLSTIC »
You wouldn't have some kind of CVT between the engine and flywheel would you? It wouldn't work continuously, but you could get a few seconds of steady state in.
Or as has been mentioned, a retarder of some kind on the flywheel
Is there torque measurement on the shaft between the flywheel and engine? I'm wildly guessing at this point but if you had data at that point you could calculate quite a lot...
Kevin Johnson
Post by Kevin Johnson »
The integral calculus. Progression to infinitesimals can be a defined step function and each step is a steady state of finite but defined duration. Think about the riser and tread in a staircase.
mekilljoydammit
Kevin Johnson wrote: Thu Dec 05, 2019 2:57 am The integral calculus. Progression to infinitesimals can be a defined step function and each step is a steady state of finite but defined duration. Think about the riser and tread in a staircase.
Right, but if you go that path, you're going to have to deal with that the engine isn't truly steady state but has power pulses and the like. Also he did talk about holding specific ramp rates, which to my mind argues against a math based solution
Kevin Johnson
mekilljoydammit wrote: Thu Dec 05, 2019 8:24 am
The power pulses are part of the claims (in-cylinder pressures).
Ramp rates. LOL. Welcome to Zeno's paradoxes. You would need a sample of the signal produced by the machine self-regulating at the target sweep rate. This might already exist in a large table or be calculated. This can then be extracted/removed/masked from the testing pull.
Really, I think the signal processing capabilities have long existed ala submarine warfare but were probably considered munitions.
Anyways, I have work to do -- perhaps David will explain along a completely different vein.
