Dart sbc little m
fishman
Dart sbc little m
Post by fishman »
How many rebuilds do you do before you replace the ARP main cap Bearings bolts. I have two rebuilds on the bolts right now. Motor has 650 hp and spins 7000rpm . I know dart recommends to replace every two or three rebuilds. Thanks in advance
[IMG]http://i44.photobucket.com/albums/f29/fishman1/S7300198-1.jpg[/IMG]
steve cowan
Re: Dart sbc little m
Post by steve cowan »
i dont have a answer to your question sorry,
i just purchased a Dart little M and at machine shop at the moment,
i have read some rocker oiling issues,is there any tips or things you have found on the dart blocks
i apologize for the hijack
77cruiser
Post by 77cruiser »
A couple little things. Might have to tap threaded holes deeper too.
Jim
novafornow
Post by novafornow »
Yea, the main thing that I remember is tapping the pipe plug holes deeper. De-burr the cam bearing bores and the freeze plug holes. I fact, an overall de-burr is probably necessary.
tenxal
Post by tenxal »
steve cowan wrote: Tue Dec 10, 2019 2:44 amI just purchased a Dart little M and at machine shop at the moment,i have read some rocker oiling issues,is there any tips or things you have found on the dart blocks.
Steve, be sure to check the lifter bores diameter against the lifters you're going to use. The Dart lifter bores are a bit on the small side (intentionally) for better lifter clearance.
