What 1st Gen. Camaro upper adjustable A-Arms are you guys using?
I want to install adjustable tubular upper A-Arms on my '67 Camaro and only know about the ones sold by SC&C.
What else is available AND safe to use?
In other words NOT e-bay el-cheapo jobbers unless you are happy to recommend them for installation.
Re: What 1st Gen. Camaro upper adjustable A-Arms are you guys using?
Detroit speed A- arm kit is pricey but nice
https://www.detroitspeed.com/speed-kit- ... -ls-031301
Here is a link to a discussion of tubular a arms.
https://www.camaros.net/forums/16-brake ... 513?page=1
Or, you could do the Gullstrand modification to your Camaro
http://www.pozziracing.com/first_gen_su ... er%20mount
Are there any other double adjustable upper A-Arms for a 1st Gen. Camaro out there besides SC&C?
Please advise and thanks for any help..
Everybody saying that SC&C has the only 1st Gen. car double adjustable upper A-Arms out there?
Rob,
I need to pull my upper A-Arms in quite a bit due to my Pro-Motorsports 2-15/16" tall spindle extenders is why I want adjustable uppers.
I also have SHORT cut STIFF coil springs and the Pony-car Bullitt 8" wide rims on my car.
Does HOWE racing make anything like what you want?
Ken
Ken
Over the hill but still learning!
Retaining it is the hard part.
Donno, that's why I am asking who else sells them?
How do SPC upper control adjustable A-Arms work?
Or is SC&C reselling them??
"Pro-Motorsports 2-15/16" tall spindle extenders "
Does that accomplish the same thing as the "GULDSTRAND" MOD?
They raise the upper ball joint position 2-15/16" so that the poor 1st Gen. front roll center is raised.
I have four stock forged spindles and really want to section them and weld them together to raise their upper ball joint position about 1.5", but don't know who would weld, then heat treat and x-ray them to make sure they would be safe to use.
Please, again...
Would really like to do this IF possible??
"I have four stock forged spindles and really want to section them and weld them together to raise their upper ball joint position about 1.5", but don't know who would weld, then heat treat and x-ray them to make sure they would be safe to use."
Like these?
https://smithracecraft.com/product-cate ... ntrol-arms
You could probably get a longer Howe ball joint.
https://howeracing.com/index.php/store/ ... s.html?p=1
We use the Smith a-arms, the lowers have a coil over mount for the Santhuff shocks with a conical spring to the factory spring bucket.
