Weld Draglite/Prostar
Man, I know it's been a long time since I bought wheels for anything, but holy hell. These things were always the default, affordable go-fast wheels at around $100 each. Now they're more than double at $225-$250. What happened?!
DON'T PANIC
Re: Weld Draglite/Prostar
Those days are long gone......turbo camino wrote: ↑Fri Dec 27, 2019 6:39 amMan, I know it's been a long time since I bought wheels for anything, but holy hell. These things were always the default, affordable go-fast wheels at around $100 each. Now they're more than double at $225-$250. What happened?!
If you mean the days of ordinary people buying Weld wheels are over, then I guess you're right.
DON'T PANIC
None of the other wheels that have been available over the same time period have doubled in price. $100 wheels can still be had for around $100 as long as they aren't made by Weld. Steel rally wheels and D-hole dirt wheels are still $50-60 each. So, that's what made me mention it at all. Something odd going on with them. A thousand dollars for a set of 15x8 Draglites is just flat-out stupid.
DON'T PANIC
That's chump change. Price out a set of Forgelines.turbo camino wrote: ↑Fri Dec 27, 2019 12:31 pm A thousand dollars for a set of 15x8 Draglites is just flat-out stupid.
Ken
Over the hill but still learning!
Retaining it is the hard part.
Take a look at the Race Star wheels. Their 92 series wheels are pretty nice....a pal has a set and I was impressed with them. If you have an NHRA or IHRA permanent number, Jegs and Summit offer additional discounts.turbo camino wrote: ↑Fri Dec 27, 2019 8:49 amIf you mean the days of ordinary people buying Weld wheels are over, then I guess you're right.
There's always been wheels that cost stupid amounts of money, marketed to people who won the inheritance lottery or whatever. Expensive wheels are still expensive.Kenova wrote: ↑Fri Dec 27, 2019 3:53 pmThat's chump change. Price out a set of Forgelines.turbo camino wrote: ↑Fri Dec 27, 2019 12:31 pm A thousand dollars for a set of 15x8 Draglites is just flat-out stupid.
Ken
Weld Alumastars were always more money, $250 for a plain non-beadlock wheel back in the day when the comparable Draglite/Prostar was $100 - that same Alumastar today is $500. One single manufacturer deciding to double the price of everything they make is what seems odd.
DON'T PANIC
It's not just Weld....all race wheels have increased in price. Weld held the line on pricing for many years.turbo camino wrote: ↑Sat Dec 28, 2019 1:36 am One single manufacturer deciding to double the price of everything they make is what seems odd.
What sizes/back spacing/bolt circle are you looking for?
Just basic 5x4.75, 15x6 ~3" BS, 15x8 3.5-4" BS. I did find Torq-Thrust IIs in those sizes for ~$100 each.
DON'T PANIC
when i was 18 i started work as a welder for $8.50 per hour. That was 24 years ago. When i quit welding i was getting paid by the job but i averaged $40 - $50 per hour. The only way those wheels can stay cheap is if Weld gets them made in China. If people want that, then they will probably do it.
Brian
Brian
And my income has gone down slightly over that same period of time. But, congrats on your success.
DON'T PANIC
I wasn't trying to brag about my success. I'm guessing you are much older than me and hopefully your income went up from when you were 18 until you were 42. I don't like paying big money for race car parts either. Canadians know what its like to pay through the nose for race car parts. Europe and Australians have it even worse. If you live in mainland USA you got it good. Many shops even give you free shipping.
I thought you were looking for something light weight? If not, there's tons of wheels out there that will work in that price range....Jegs cast knock off versions of the Welds, for example.turbo camino wrote: ↑Tue Dec 31, 2019 1:48 pmI did find Torq-Thrust IIs in those sizes for ~$100 each.
From my prior thread!
Who will widen aluminum wheels?? Like cut the wider back space off and weld it on the front face and visa versa..
