offset valve seats
sbcharlie
offset valve seats
Post by sbcharlie »
here is a picture of a Harley Davidson twin cam with offset valve seat. they work quite well
sbcharlie
Re: offset valve seats
Post by sbcharlie »
Pictures of the cylinder head
sbcharlie
Post by sbcharlie »
Machining offset seat
Sparksalot
Post by Sparksalot »
Interesting application of an age old speed "secret" of moving valve center(s) and or angles to gain performance. It still works if the application is happy with the change.
First did it in 1961 on a Studebaker V8. It worked. Many happy years followed.
jarmoyp
Post by jarmoyp »
I have done this many times, moved valve centerlines.
Why to the hd twin cam? Is it because of valve overlap?
gordon
Post by gordon »
On the Stude V8 which direction did you move the valve? EX or INT?
HDBD
Post by HDBD »
This is different. He just moved the throat. The seat and guide are located stock
sbcharlie
Post by sbcharlie »
No remove the stock seat. And then bore new seat pocket offset.
HDBD
Post by HDBD »
OK I get it, guide and valve are still unchanged however.
jarmoyp
Post by jarmoyp »
Ok. This is a very common way to make a seat by hand porting after seat job. It takes a couple of minute to do that move.
Truckedup
Post by Truckedup »
Ok, for the stupid like me....How do you move a valve seat without moving the guide? You are talking lateral moves and not in or out ?
jed
Post by jed »
I can see the valve seat is moved but don't understand what it accomplishes?? The valve has not moved
In relation to the port.
jarmoyp
Post by jarmoyp »
The throat or venturi is not round after offset portning. Short side radius is better after that move. I do this every time, for every head when porting.
jed
Post by jed »
Thanks I get the concept. It seems that it would add a lot of dollars to the porting job for 8 off set intake seats and
8 exhaust seats. What is the return on investment in terms of CFM and torque.
HDBD
Post by HDBD »
Good question, I would be more interested in hp and tq with a back to back test. Added flow does not always equal more of either
