LS3 Carbed build
steve cowan
Re: LS3 Carbed build
Post by steve cowan »
CGT wrote: Tue Jan 28, 2020 8:59 am 20200127_215439.jpg
New cam on the left. Old cam on the right. Most likely not much change...ill find out.
Chad,
sorry, i can not read those cam cards even with my glasses'' on''
CGT
Post by CGT »
steve cowan wrote: Tue Jan 28, 2020 1:16 pm
Chad,
That any better?
steve cowan
:D :D :D
CGT
Post by CGT »
Ready to load up. Should have some new dyno data this week.
steve cowan
Chad,
Bigger cam push peaks up 200-300 rpm and spreading lobe centres will probably carry power past peak nicely,
If I remember last dyno session your engine peaks at 7500 rpm more than likely peak 7700-7800
What are your thoughts on hydraulic lifters, will they handle the extra rpm??
I am trying to remember if you revved engine to 8000 rpm last dyno session :D
randy331
Post by randy331 »
Is one of them speced with flowZ ?
Here's a thread you may want to read before ordering a 3rd cam. Talk of pros n cons of using flowZ to spec cams. :D
viewtopic.php?f=1&t=59855
Randy
CGT
Post by CGT »
steve cowan wrote: Tue Jan 28, 2020 7:22 pm Chad,
I pulled it to 7700 a couple times, that's the highest it's been. It was peaking at 7500 with vacuum on it so I went to 7700 to try and find peak, with no vacuum on it after the pump broke..it was down a few hundred rpms, lower 7000ish peak...the horsepower is very flat up there so where it finds peak from pull to pull can seem a little random.
I feel the valvetrain will sound good to 8000, but I know from messing with hydraulic rollers...they don't give you much warning before they stop sounding good :oops: . The question is, even if it sounds fine..how much of my cam lobes are the valves actually seeing? ….I'm not expecting to see much from the cam swap, I'm guessing a little better here, a little worse there.
CGT
Post by CGT »
CGT
Post by CGT »
GARY C
Post by GARY C »
It's not giving up any power with RPM so I would guess the valve train is pretty stable. Would it be better with solid rollers? Only testing would tell.
steve cowan
i watched the dyno run several times
i seen 770 hp and 8400 rpm,might not be what is on the sheets but thats what i seen on Joes console.
for 360 ci i am blown away at the moment.
hydraulic cam,cast crank and rods,stock rockers,factory heads.
Chad
how was oil pressure and vacuum this time round,damn sounds really strong on the dyno :D
steve cowan
i also seen 560 ft/LBS @ 6009rpm
560/376 = 1.48 FT/LBS per ci :D :D
randy331
Post by randy331 »
2 HP per cube. nice.
Steve, you should here it in person. :D
Needs a solid roller.
Randy
steve cowan
i am looking forward to Chads opinion on the cam change,
averages below and above peaks,its a beast for sure.
Tony Knight mentioned last year on a hydraulic roller he was gaining rpm where the lifter was remaining stable,running a hydraulic above 8000 is very impressive.
CGT
Post by CGT »
Well, been looking everything over. Cam 2 is a better cam...in this engine anyway. It's down a bit or equal to cam 1 below 6200 but is better after that. It is 10 or 15 better on average after 7000...and is smoother, more consistent up there. It appears to keep the valvetrain more stable. Same lobe families, so think about that one for a minute.
We did a few pulls on Q16, and the pull on the videos was one of those. The best pull on Q was 763hp and 560 torque, I'm not convinced at all that it has peaked yet. The best pull on the Late model plus fuel was 758hp and 550 torque. Just noticed, I have 59 pulls on this thing already :lol:
New vacuum pump seems fine, the Schumann ER oil pump system did not change the oil pressure issue in any way that I can tell...other theories are evolving :P So that was a bit upsetting. Probably won't be the last 500.00 I will light on fire :oops:
Biggest hp gains from the 2 day session.... the decision to turn the engine higher.
