Best oil for 6.7 Cummins
modok
Re: Best oil for 6.7 Cummins
Post by modok »
All choices listed sound good to me
Oil change intervals based on miles are not telling the whole story, equally important is the number of HOURS.
Avoid idling when possible, because the emissions system on these newer modles makes life hard on the engine, washing down your cylinders to keep the soot filter HOT.
Krooser
Post by Krooser »
MELWAY wrote: Sun Feb 02, 2020 4:07 pm
Krooser wrote: Sun Feb 02, 2020 12:47 pm I have had better results in my big diesels with Delvac...better oil samples with higher TBN numbers after a 50,000 mile oil change interval. Lucas and Schaeffer are very good, too. Rotella always fell short.
Are you referring to delvac 1 full synthetic? 50000 is a long time for oil to be in an engine
Nope...Delvac dino oil. The key was 3% idle time...
MELWAY
Post by MELWAY »
Wow. Thanks Graig. Interesting
I have been using delvac MX or Cat DEO in my light common rail engines. But I change it at 8000km. I hate black oil. Lol and it’s cheap
cjperformance
Post by cjperformance »
MELWAY wrote: Mon Feb 03, 2020 12:52 am Wow. Thanks Graig. Interesting
Does your EGR valve work as per factory or has it mysteriously been blocked up with a "blank gasket" :lol: ?
Craig.
MELWAY
Post by MELWAY »
cjperformance wrote: Mon Feb 03, 2020 1:08 am
No I was told that will throw fault codes. It’s an Isuzu Dmax
I had ecu re mapped they told me it will reduce EGR activity but NOT eliminate it. I’m all ears if you know ways around it
cjperformance
MELWAY wrote: Mon Feb 03, 2020 3:00 am
Ah , not on DMax, i dont know an easy EGR delete on them. Great vehicle though, I'll take a dmax over any of the other similar vehicles no problem.
Even a reduction in egr is great.
Do you know what tune was used in yours?
Craig.
MELWAY
Post by MELWAY »
cjperformance wrote: Mon Feb 03, 2020 5:43 am
It’s a roo systems towing and touring tune. It made 34rwkw. More
It changed to Ute from being a slug that I hated to something decent. I have raced stock rangers and stay on their door past 100mph. And it’s amazing on fuel
