Extra Clearance Bearings, Use One half, Top or Bottom?
n2omike
Post by n2omike »
With extra clearance bearings, I know you can use only one if only half a thou is needed. I believe I remember it being said it's best to use the extra clearance bearing in either the top or bottom... but cannot remember which.
So, do I put the looser bearing shell in the top or bottom... or does it really matter?
Thanks!
engineguyBill
Re: Extra Clearance Bearings, Use One half, Top or Bottom?
Post by engineguyBill »
Bearing manufacturers recommend installing the thicker bearing shell in the lower position for main bearings and the upper position for rod bearings. However, I and many others have installed the thicker shells in the upper position main bearing location and the lower position of the connecting rod with no problems.
In summary, I recommend going by the bearing manufacturer's recommendations . . . . . . .
Bill
SAE Member (30 years)
n2omike
Post by n2omike »
engineguyBill wrote: Thu Feb 06, 2020 11:41 am Bearing manufacturers recommend installing the thicker bearing shell in the lower position for main bearings and the upper position for rod bearings. However, I and many others have installed the thicker shells in the upper position main bearing location and the lower position of the connecting rod with no problems.
Thanks for the reply, Bill. I appreciate it!
BlitzA64
Post by BlitzA64 »
I have used them both ways myself, never saw an issue either way on disassembly. I guess like Bill said go with the bearing mfg suggestion, I always saved the extra bearings to use rather than use half a set then throw away the rest
needforspeed66gt
Post by needforspeed66gt »
BlitzA64 wrote: Thu Feb 06, 2020 1:29 pm I have used them both ways myself, never saw an issue either way on disassembly. I guess like Bill said go with the bearing mfg suggestion, I always saved the extra bearings to use rather than use half a set then throw away the rest
Yep - I've done this too many times to count, never a problem and they look exactly the same on teardown.
Nate @steeldustmachine
Engine Machinist
modok
Post by modok »
I was taught to use the thinner shell in the cap.
I can imagine some situations where the reverse would work better, tho it would be a rare case.
BILL-C
Post by BILL-C »
We have used the thinner halves in either location in several hundred race engines with no issues.
Carlquist Competition Engines
PFC1
Post by PFC1 »
Maybe the bearing companies recommend only using certain halves in certain locations so you'll waste more bearing/thus they sell more. Just a thought. I regularly use them both ways w/o issue.
Pullin' for Christ
EDC
Post by EDC »
Would it really make a difference?
As long as the "thick" shells were installed on one side and the "thin" on the opposite, how would the crank/block know?
We're talking a .0005" delta?
Nil Satis Nisi Optimum
