https://www.yellowbullet.com/threads/ra ... on.618754/
George Bryce
Discussion Starter • #1 • Nov 24, 2013
StanIf I go real fast and my engine cranks over at 300 psi...what should it be?
If I loosen the lash .010 and it pumps over at 320 psi is this better?
What if I keep working and I get it up to 350 psi cranking...and I need 2, 800 CCA batteries and need to wire them to give me 24 volts to rotate the engine to test cranking compression? Will it go faster. Looking for opinions . Thanks
