SB2.2 EVILNESS
SpeierRacingHeads
SB2.2 EVILNESS
Post by SpeierRacingHeads »
3.21in² MIN at the throat. 440+cfm
Speier Racing Heads
Chad Speier
785-623-0963
CamKing
Re: SB2.2 EVILNESS
Post by CamKing »
I hope you have a tall block, raised cam, 440cid, underneath those.
SpeierRacingHeads
Re: SB2.2 EVILNESS
CamKing wrote: Thu Feb 13, 2020 1:39 pm I hope you have a tall block, raised cam, 440cid, underneath those.
Or a 358 B/DA engine! :)
Speier Racing Heads
Chad Speier
785-623-0963
FC-Pilot
Re: SB2.2 EVILNESS
Post by FC-Pilot »
I am impressed with the sb2 architecture, but isn’t there better heads for the application? I would imagine the old pro stock truck heads (I can’t remember what they are called right now, splayed valve I think) might be a better application fit. Unless intake design for single carb is the issue. What are your thoughts Chad and why? Just trying to learn.
SpeierRacingHeads
Re: SB2.2 EVILNESS
FC-Pilot wrote: Sat Feb 15, 2020 4:09 am I am impressed with the sb2 architecture, but isn’t there better heads for the application? I would imagine the old pro stock truck heads (I can’t remember what they are called right now, splayed valve I think) might be a better application fit. Unless intake design for single carb is the issue. What are your thoughts Chad and why? Just trying to learn.
Most of the altered classes are canted only and not splayed.
A GM splayed valve head, ported to the max, will crack just looking at it. True story.
Speier Racing Heads
Chad Speier
785-623-0963
FC-Pilot
Re: SB2.2 EVILNESS
Post by FC-Pilot »
SpeierRacingHeads wrote: Mon Feb 17, 2020 4:27 pm
Have not cared much about comp rules in over a decade so forgot much of its particulars as far as rules went. Did not know that about those heads though. Very interesting. Thanks for the response.
