Bench Data
Re: Bench Data
Should be ~ 3300#.
SpeierRacingHeads
Re: Bench Data
Post by SpeierRacingHeads »
This is happening this week.
New 1 7/8 longtubes, 3" Y pipe and 4"..
Tailpipe.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Re: Bench Data
I think this Mufflex Y pipe and 4" exhaust is going to work out pretty good!
Speier Racing Heads
Chad Speier
785-623-0963
Kenny M
Re: Bench Data
Post by Kenny M »
MadBill wrote: Wed Jan 29, 2020 8:42 pm Should be ~ 3300#.
Just put mine on the scales. 89 Iroc T-Top Loaded Half tank of fuel . No driver. 3293Lbs
SpeierRacingHeads
Re: Bench Data
Long tube headers with 3" collecter into a Mufflex 3" Y-Pipe into a Mufflex single 4" to the tailpipe with a Flowmaster muffler.
Speier Racing Heads
Chad Speier
785-623-0963
Re: Bench Data
Kenny M wrote: Fri Feb 21, 2020 11:55 am
Must'a had about a gallon less than half a tank... :P
splitdecision71
Re: Bench Data
Post by splitdecision71 »
SpeierRacingHeads wrote: Fri Oct 18, 2019 5:21 pm Image
I notice in the pic of intake gaskets on the heads that the gaskets are a tad bigger than the ports. Is this acceptable with no ill affects on the flow? I am currently putting together a 421 sbc with some Pontiac 867 heads that have some very nice work done to them. The 1209 intake gaskets are a slight bit bigger similar to what I see in your picture. I want to make sure this is ok? Very nice build by the way and loved reading about it!
SpeierRacingHeads
Re: Bench Data
Much have it a little bigger than smaller and hanging in the port because it wasn't trimmed.
Speier Racing Heads
Chad Speier
785-623-0963
splitdecision71
Re: Bench Data
SpeierRacingHeads wrote: Tue Feb 25, 2020 10:31 am
Ok thank you.
GARY C
Re: Bench Data
Post by GARY C »
splitdecision71 wrote: Tue Feb 25, 2020 10:13 am
I think I would buy trim to fit gaskets if I was going to try to solve the problem but I would not try to match the port to a shelf gasket that was sized and shaped from the 60's. :)
SpeierRacingHeads
Re: Bench Data
So I finally got to drive the Camaro with the new "ram air".. Key on and in this part of the country I show 91 kPa.. Went and drove it with the computer hooked up. Put my foot in it and it shows 90 kPa. MISSION ACCOMPLISHED.
Speier Racing Heads
Chad Speier
785-623-0963
