Charging-at-a-Distance-While-in-Motion?
Anything to do with the electric or hybrid world
Kevin Johnson
Re: Charging-at-a-Distance-While-in-Motion?
Post by Kevin Johnson »
GRTfast wrote: Thu Jun 11, 2020 8:19 am ...
I just put a new cam in the prime mover of my motor car. :lol:
I can remember being the prime mover when the starter motor went bad. Then I handed off the title as I jumped in and dropped it in gear.
GRTfast
Post by GRTfast »
GLHS60 wrote: Thu Jun 11, 2020 2:41 pm I appreciate the link!!
Obviously there was enormous thought in producing this document.
The Military proves there is no logical reason to call an Engine a motor.
The terminology is as accurate and unemotional as is humanly possible.
Combustion powerplants are constantly referred to as Engines and specified:
EG: Outboard Engine, Steam Engine, Motorcycle Engine, Diesel Engine, etc.
A Submariner ordered to the Engine room shouldn't go to the E-motor room!
The terms are so logical, it accepts a propeller shaft could be a drive shaft.
Not once does it even consider an Engine could ever be called a motor.
Please keep safe!!
Thanks
Randy
Kevin Johnson wrote: Thu Jun 11, 2020 3:31 am http://everyspec.com/ARMY/ARMY-General/ ... 055539.pdf
You might enjoy the above; extensive use is made of the term '"prime mover."
GLHS60 wrote: Thu Jun 11, 2020 12:25 am Gentle Friend:
Coincidentally, I just noticed this Technical Reference on another thread.
The author nicely defines vehicle powerplants on PDF pages 81-82
Steam Engine, electric motor and internal combustion Engine.
I hope you find the poster credible, I know I certainly do.
Comments/criticisms gratefully accepted.
Thanks
Randy
http://www.edccorp.com/library/TechRefPdfs/EDC-1110.pdf
Internal combustion engines are motors. You can author a million posts on the topic, but that fact will remain. :lol:
gruntguru
Post by gruntguru »
Did you find it with the Google search motor?
Kevin Johnson
GLHS60 wrote: Thu Jun 11, 2020 4:14 pm I got a suggestion to do a German-English translation of the M in BMW.
Interesting!!
Thanks
Randy
https://www.google.com/search?q=transla ... e&ie=UTF-8
Kevin Johnson wrote: Wed Jun 10, 2020 9:12 am
When I lived in Illinois and Michigan there were still many people that spoke German as a primary/secondary language and so "motor" was in common usage as a borrowed term. The land that I lived on in Illinois once belonged to the German family whose descendant was my High School German teacher. A number of the workers in my Grandfather's laboratory in Detroit spoke German.
The gender of the German word "Motor" is masculine (der Motor). The plural is die Motoren.
So, here are Carl Benz' German and US Patents circa 1880's; I encourage all the budding comparative linguists*:
https://upload.wikimedia.org/wikipedia/ ... rwagen.pdf
https://patentimages.storage.googleapis ... 385087.pdf
* https://en.wikipedia.org/wiki/Comparative_linguistics
gruntguru
Post by gruntguru »
Kevin Johnson wrote: Thu Jun 11, 2020 6:50 pmSo, here are Carl Benz' German and US Patents circa 1880's; I encourage all the budding comparative linguists*:
Sure but what would the inventor of the motor car know?
Kevin Johnson
gruntguru wrote: Thu Jun 11, 2020 6:49 pm
Google Suchmachine (verb suchen -- to search or look for)
https://www.google.de/search?source=hp& ... ent=psy-ab
gruntguru
Post by gruntguru »
The word "engine" is not used in German. The words motor and maschine do the job OK. https://www.linguee.com/english-german/ ... ngine.html
Similarly in English, the words motor and machine can be used for any powerplant. Motors are members of the machine family and engines are members of the motor family.
Kevin Johnson
GLHS60 wrote: Fri Jun 12, 2020 2:02 am The point is Audi, BMW and Mercedes all call their Engines -- Engines.
The learned can fudge it if they want, but the motor car companies do not.
If motor were a logical synonym, at times a motor car company would use it.
Cough. 2018
https://patents.google.com/patent/US10380988B1/en
Noise cancellation may be employed to cancel out undesirable sounds associated with, for example, deactivating one or more cylinders of a multi-cylinder motor.
The desired noise cancellation signal may also be below the audible frequency range. In an example, the desired noise cancellation signal may be emitted to counteract sounds produced when cylinders of a multi-cylinder engine (not shown) are deactivated.
Oddly, all the authors listed on the patent live in Michigan; employed by GM (General Motors).
:wink: :lol:
https://www.linkedin.com/in/frank-valeri-8499096/
https://www.designnews.com/content/concert-hall-cadillac/109980178953908 wrote: ... says Scott Reilly, noise integration engineer for Cadillac's luxury car division.
https://www.linkedin.com/in/ericdefenderfer/
GRTfast
Post by GRTfast »
GLHS60 wrote: Fri Jun 12, 2020 2:46 pm It's been said there is a fine line between genius and insanity!!
I concede your education and search abilities undoubtedly far exceed mine.
My discussion is based in honesty as I have/will/ provide counter proof.
Strangely, when I looked at your application I wasn't able to find your quote.
I don't doubt your sentence is somewhere in the link, just I couldn't find it.
What I did find is this sentence:
"emitted to counteract sounds produced when cylinders of a multi-cylinder engine"
This caused me to re-read and re-read your post then I noticed...
It's conveniently placed low in your quote and unseen unless fully scrolled.
I didn't see the "shadow banned part" until I re-scrolled your post quote.
I don't even know how you shadow banned that part or why you did?
I'll assume internet trickery is below your level of integrity.
Thanks
Randy
Kevin Johnson wrote: Fri Jun 12, 2020 6:03 am
Cough. 2018
:wink: :lol:
Dude... you prefer to call the machine that powers a car by converting the chemical energy in the fuel to heat, and then to rotating motion an engine.. AND this type of engine is a motor. These are FACTS.
This doesn't have anything to do with logic.
Why is it such a sticking point for you? Call it an engine all you like, I usually do as well. Despite anything you say, when someone calls it a motor, they are not wrong AT ALL and they are not being illogical AT ALL.
/thread
Kevin Johnson
The quotes can be found more succinctly if you download the pdf: Column 3 lines 63-66 and column 4 lines 33-36.
I used the ellipsis (...) and spacing in an attempt to illustrate that there was some separation between the sentences in the document. The effect that you are describing is an artifact of the board software.
Thanks
Randy
Cough. 2018
:wink: :lol:
GRTfast
Post by GRTfast »
GLHS60 wrote: Sat Jun 13, 2020 2:50 am I didn't mean to sound like I was accusing you of anything.
I'm not very internet or computer savvy but appreciate the discussion.
It continually amazes me how you come up with such obscure information!!
Still, I think your searching often helps me with my very simple viewpoint.
Current motor car companies only ever say Engine, unless talking electric.
Brochures, advertisements, manuals etc, etc always specify Engine specs.
Your patent info no doubt was prepared by educated lawyers/assistants.
The same patent uses the multi cyl Engine and motor term as you provided.
Like dictionaries, they seem to speak in general terms covering all bases.
The motor car companies haven't been confusing the two since the 1940's.
From the 1950's on they never use the word motor, when talking Engines.
They continually assert there's no logical reason to call an Engine a motor.
I very simply agree with their obvious, logical assertions.
I have nothing outstanding or unusual to prove.
I simply agree with the motor car companies.
I'm not enlightened enough to disagree.
Thanks
Randy
There is no confusion with the two terms. All internal combustion engines are motors. This is an indisputable fact that you seem to be unable to acknowledge.
Calling an internal combustion engine a motor is less specific, just as calling a blue-jay a bird is less specific. Neither is wrong or illogical. In the context of hotrods and race cars, literally everyone knows what is meant when someone says "motor", just like everyone knows what is meant when someone "bird" at a blue-jay sanctuary.
