All good stuff, I will add again though, likely time to build the whole thing again
Better heads will likely have slightly different valve locations or bigger valves and a hyper piston is not optimal and may not have radial clearance. A 1mm/3mm ring set will gain power too, in addition to safety with a forged piston as power climbs.
Then of course if starting from a clean slate, that allows, compression, quench, heads and cam all to match desired RPM range. Which also means that has to be defined first, although likely unchanged from now if I read it correctly, not to mention the gearing and use of the car isn't changing I assume.
In the end though, that current 331 sure did good for a LONG time, I remember the original adventure. Testament to a good build for sure!
Modification advice for 331 Ford
Re: Modification advice for 331 Ford
Bullock's Power Service, LLC
Plattsmouth, NE
Plattsmouth, NE
The .020" spec is 270 on the 282 cam. The 282 is @.015
If using the .020" spec as a benchmark it is a 270° cam.
The advertized duration of all those cams is not the seat to seat duration @lashpoint.
I've seen those lobes before. I think they were called XE Solid lobes. The 7394 was something I was curious about several years ago. It's got 7 deg more duration @ .200 with the same .050 duration. So 7394 plus 7404 with 108 LSA...and some AFR 185 renegades...! I could probably sell my ported DOOEs for a decent price given how well they did. I'd have to probably have to get new headers. My Dougs stepped tri-ys were port matched to my ported and raised exhaust ports which measured 1.48 x 1.25. I could step up to some 1.75 primary long tubes so long as they have decent ground clearance and port them to match the 185s if necessary. My Vic Jr intake would probably have to go too. It was port matched to the raised intake ports that were the dimensions of a Felpro 1262. I like the idea of a RPM air gap.frnkeore wrote: ↑Mon Jun 22, 2020 2:35 am So, the one thing that we know that he wants to do, is change out the cam, I believe. So, I have CC and Howards complete lobe list.
First, is Black Ford's cam lobe to compare with others:
----------------------------- Lift at CL
Lobe Aver .050-.200- lift-106 -110 --1.6 --1.7
6002 282-2 236 145 .330 .082 .069 .528 .561
These next lobes are CC, .875 SFT lobes:
7394 262 --236 152 .357 .089 .075 .571 .607
7395 264 --238 154 .359 .093 .078 .574 .610
7404 266 --240 156 .361 .096 .082 .578 .614
This last 2 are the lobes on my CC, camshaft. Note, my much more aggressive, ex lobe has the same "advertised" duration as Black Fords current cam but, both the in and ex aren't even in the same league as the 282, .842 lobe:
7409 278 --252 168 .373 .118 .104 .597 .634
7411 282 --256 172 .380 .126 .111 .608 .646
Howards .875 lobes:
Lobe#----@.020 .050 .200 lift - lash --1.6 ---1.7
FF2363588A 264 236 153 0.359 0.018 .5741 .6100
FF2403685A 268 240 157 0.369 0.018 .5896 .6265
Just as a suggestion, I would use your same .050 duration but, with the .875 lobes and you'll have less seat overlap, much more .200 duration and .046-.049 more lift on the intake. For the ex, I'd go 4 more duration and use a 108 - 110 LSA. ICL ~104
I think it's a safe bet and would make a much different mid range engine.
A couple of things from the last post
1. The XE-style lobes can do OK, but when you get to a lower difference between adv and .050, the ramp can become uncontrollable. Likely not at the level of RPM and cam that you would run if you went with a street/strip lobe like that, but they can be pretty noisy compared to what you have. Not to mention, the XE lobes aren't that impressive for power anyway. Best to buy a custom cam that matches the parts.
That being said, just picking from specs can be dangerous. The 7394 and 7404 is NOT a street/strip lobe. In fact, talking to Comp regularly about lobe design, you don't just want to use the numbers to pick a lobe when going custom.. There are plenty of numbers NOT in the catalog, specifically showing acceleration rates and lifter velocity changes that make a race lobe undesirable. I think the 7394 is going to be tough to break in and need some decent spring to turn the RPM you turn, I personally wouldn't go nearly that aggressive. Also note in Comp's catalog that they recommend oiling mods and shaft mounted rockers for those lobes. That's code for "aggressive" and likely not in a good way considering how long you keep your engines together
2. The air gap is a good intake, but I think with your 1st gear ratio and depending on the cam you choose, likely not needed unless you don't think you can keep the shape within the confines of the roof of the 185s. If it won't fit the heads, fine, but if you go Air Gap, be sure to do a little plenum work in the roof especially, and gasket match the best you can
I like single planes and Victor series myself, and I would likely use the single plane and shape it to what I needed, but either would work, as you see now.
Finally, be careful of talking yourself into a cam until you work through everything. I know you have been considering this upgrade for a long time, the heads alone will be significant, but remember all the parts associated with it can add power and/or add additional stress. Something that will stay together a long time, run up and down the PCH, or do a coffee cruise, even if racing too, has a different design than a pure racer
Plattsmouth, NE
Plattsmouth, NE
On ALL those .875" lifter ford solids do not assume that the real seat to seat duration will be less.
These cams will not act tamer nor be more "drivable".
The faster the lift rate the more spring pressure required.
May expect less service life in a street car.
Comp recomends that you contact them on these racy MHF cam lobes. (critical break in, proper springs, oiling, service life.
There is no free lunch...
This is why Comp has the street strip friendly mechanical roller cams XR series. Lunati has simular purpose Voodoo and "new" street strip solid rollers that can take you to the next level.
These were the XE lobes I was thinking about. They don't require any special oiling lifters and a bit larger than the Magnum lobes. I often wondered if I got a cam with 6055 lobes as compared to the 282S. It would have been a tiny bit larger and probably would not have made a huge difference, but i've often wondered. Running my 282S tighter than .015 tappet lash is probably making it very similar to the 6055 in terms of .200 duration anyhow. I didn't know about the master lobe catalog until after I built my engine in '04.My427stang wrote: ↑Tue Jun 23, 2020 7:40 am A couple of things from the last post
I don't want to use a cam that requires special oiling requirements...too aggressive for my liking. That's one thing I like about the 282S Magnum. It's not super aggressive, it's not noisy, and it's easy on parts. I was unaware the 7394 plus 7404 were MHF solids...they are too aggressive for me. I put a lot of thought in choosing the 282S and will take my time choosing another if I decide to try a new cam. I would ultimately like to talk to a custom cam supplier.
I might just try new heads and 10.5:1 compression and see how it runs.
@ .050” @ .200” 106° 110° 1.5 1.6 1.7
6055 274 236 147 .335 .087 .073 .503 .536 .570
6056 280 242 153 .341 .097 .083 .512 .546 .580
6057 282 244 156 .347 .101 .087 .521 .555 .590
6089 290 252 164 .352 .115 .101 .528 .563 .598
6059 290 252 164 .361 .115 .101 .542 .578 .614
6091 298 260 171 .352 .129 .155 .528 .563 .598
6061 298 260 172 .373 .129 .155 .560 .597 .634
I believe Mike Jones will give you really good advise on whether to keep your current cam or something different. The keys is, as always, defining what you want. I am pleased with the cam Mike did for me.blackford wrote: ↑Tue Jun 23, 2020 1:40 pmThese were the XE lobes I was thinking about. They don't require any special oiling lifters and a bit larger than the Magnum lobes. I often wondered if I got a cam with 6055 lobes as compared to the 282S. It would have been a tiny bit larger and probably would not have made a huge difference, but i've often wondered. Running my 282S tighter than .015 tappet lash is probably making it very similar to the 6055 in terms of .200 duration anyhow. I didn't know about the master lobe catalog until after I built my engine in '04.My427stang wrote: ↑Tue Jun 23, 2020 7:40 am A couple of things from the last post
Any updates on this project ?
Tracy.
The rod to stroke ratio is 1.586 nearly the same as a 5.4 rod 347. @ 1.588. The biggest issue is how far it pulls out of the bottom of the block but after 14+ years of operation it must be OK. Go to the AFR aluminum head for sure. Your 282S cam ( before the 1.7 ratio rockers) is slightly more than a HiPo 289 cam duration wise so another 10-20 degrees duration @ .050 will be a big gain. As I've told you on other forums , my 331 has Vic jr heads , 11.5-1- 5.315 rods and a mid 260s solid roller @ .700 lift. Yes it's race only and makes about 525 due to the "antique" Ford dual quads. Yours could easily make the same and be streetable. My plan this year is to go to the Vic Jr intake I have and ditch the dual fours. I'm over by Angel stadium in case you want to kick stuff around.
