Used Cam
Used Cam
I have an old Crane cam that I ran in my engine a few years back that I would like to install and run again.
The grind is no longer available. It's a solid lifter flat tappet cam with not that many hours on it.
I was thinking of having it REM polished first, as I can't seem to find anyone that repolishes cams.
Can I do this with a new a set of lifters without the fear of cam failure?
Dealer for Undercover Innovations, Metco,Dynamic,Fragola and many other American Made products!
Check my site http://www.lyonsperformance.com
Re: Used Cam
I can't speak about REM polishing a cam, seems like it may work, but I wouldn't be concerned with a good used cam and new lifters. Just go through the break in process to be safe, good oil, and make sure lifters are free in the bore/no binding.
Bullock's Power Service, LLC
Plattsmouth, NE
Plattsmouth, NE
Re: Used Cam
You may want to have it parkerized again, to help with break-in.
We could do it, but there may be someone closer to you.
Re: Used Cam
Before any time and money are spent, it might be wise to determine the wear characteristics of the cam, before refinishing.
A lobe evaluation using a Cam Dr, or equivalent, would reveal areas of wear not apparent to the eye.
A cam mfg can accurately measure a used cam.
Re: Used Cam
Billy Godbold mentioned in a podcast that cam cores typically have a high amount of iron in them. REM finishing removes a lot of it on the surface and leaves behind carbide peaks. He mentioned when NASCAR teams tried this it wiped out the DLC coated lifters very quickly.
He recommends a kinetic polishing of the lobes as opposed to a chemical.
-Bob
Re: Used Cam
Well I just finished cleaning the cam up in the lathe using some scotchbrite and then indicated every lobe.
All looks to spec.
I might just run it with a new set of lifters.
All looks to spec.
Re: Used Cam
Parkerizing can be done at the shop masking the bearing journals with heat resistant tape. Zinc phosphate, 95 deg for 20 min.
Re: Used Cam
Perhaps a local auto machine shop that grinds cranks can help. Most that grind cranks also have a belt polisher. Worth a call or two.
Re: Used Cam
You should not have an issue unless it is a block/lifter alignment problem. In that case nothing you put in flat tappet would live. In the 90's I had a customer that brought in his 468 for a refresh each year. Solid lifter Crane 256/266, engine ran 5.20's/30's in a short front engine dragster. He wanted new lifters put on the cam each year although the ones we took out were perfect. I did this for 5 years until he sold the car. I have never had problems with new lifters on a used cam if the cam is good. Never had problems with the original lifters put back on the cam if they are good either. I put the gray moly paste on the cam and lifter face, oiled the lifter bodies, made sure they rotated freely, used GM EOS, never lost a cam.
Re: Used Cam
My experience is the same as old schools. If you still have the old lifters and they are in order - in the same block- I would just put them in- I do usually use moly lube on them still. If they are mixed up it may be easier to just use new lifters. I have done both numerous times with no casualties - just use flattappet compatible oil or break in oil
Re: Used Cam
Just curious. When you indicated every lobe, on what basis did you determine they were in spec?
Re: Used Cam
I'm scared of those belt "polishers". Even if a sloppy old dull belt is used. A fresh 400 grit belt can be deadly.
The tendency is to keep going 'till the part is shiny.
Too often I saw nice shiny cranks with measurable ( .0002" plus ) hourglass/tapered crank journals.
When the going gets rough,that is TOO much taper on journals or rod big end bores.
Re: Used Cam
Any thoughts on running direct lube edm solid lifters and which brand?
Re: Used Cam
Nothing wrong with Crower Cool Face lifters.
As long as they start spinning immediately, should break in nicely. I wouldn't work the cam surface too hard, it is what it is, and if you can see the path of the old lifter and it's still got a little offset, assuming the bores are close to the same location, it should spin them and act like it did before.
What's the overall build?
Plattsmouth, NE
Plattsmouth, NE
Re: Used Cam
Itook pics of the cam with my phone, just can't seem to figure out how to post them.
