Ha Ha very funny...that's a solid rod...oh no wait...it has a .001 diameter oil passage
.120 vs.080 wall 3/8 pushrods sbc
Re: .120 vs.080 wall 3/8 pushrods sbc
So you have a .001 hole for the oil to lube the top end Dan
Sorry ,I did not see blackfords post till after I posted this
Don't want or mean to make your stuff seem small Adam, but mine will be 9/16 x .156 on the intake side and 5/8 x .165 on the exhaust side, appx. 9 to 9.300 long. Mark H.
In much the same manner that pushrod stiffness (bending resistance) increases exponentially with larger diameter, the reverse is true of pushrod length: stiffness decays exponentially as length is increased.
Ah, it seems Kevin Johnson has a challenger re mining the S-T depths!
- af2
And you don't have to pipe cleaners to reduce the oil...........So JK Adam
,135" 3/8 push rods is the ticket for what I am building.
GURU is only a name.
- af2
- af2
The reason is that people seem to think the push rods are part of the weighing the valve train and they get sideways on the equation. If you want a pole vault use .060" if you want stout use the .135". I hear loft and such but! I want make sure the lift is what it is when measuring my PV without guessing loft. That's all.
What I don't understand (yes, it's a long list):
There are engines with otherwise high RPM capability (CFM, pistons, rods, rockers, oil) but tight pushrod clearance in the head and/or block. This limits pushrod diameter and introduces pushrod bending and lagging valve action (the valve opens later than the tappet wants, but not linear) with some lift lost. Even a large taper (.625" bottom, .375" top) may not be small enough to clear the head, with a water leak as the penalty for a bad guess.
But the problem is the mid-point (of the unsupported span, without the ends), in which even a small diametric change is priceless.
If a 10" tube (with OD as large as can clear the target head/block tightest spot) is vetted for bending stiff by length (with OD & wall constant @ .375" & .100"), a change to 9" length increases stiffness by 37%, This may be had by using a taller tappet, lowest rocker fulcrum position, etc.
How about shortening it to 2 × 5"? Off the scale: each half is 700% greater.
Now slip the cut ends into a .100" wall sleeve 2" long, .575" OD (which probably has clearance to the inside cylinder wall, etc. as it's only .100" closer) and braze them (silver solder? epoxy?). The sleeve stiffness is 475% greater than the original 10" tube.
If there's a clearance problem in the block, the two halves may be very different as to length (3" and 7", etc.) to put the sleeve where it fits best and still achieve superior results.
Only one special part must be made (the 10" pushrods are a shelf item), and two operations added.
Yes, there's a weight penalty.
Now the questions: where is my error? It can't be that easy, or it would have been done.
I agree that a thicker pushrod provides some insurance with little down side. I just wanted to kick this can down the road a bit more though.
Those Spintron vidoes show the pushrod flexing, but they are not bending permanently. All steels generally have the same resistance to bending elastically (where the force is such that the deflection or deformation is not permanent and the material returns to its original shape when the force is removed). No matter the thickness of the walls, there is some deflection, and the thicker the wall the less the deflection. Even if a 10" pushrod were to bow .100 in the middle (that's a lot, but this is just an example), the overall length of the pushrod only changed by .002 which is virtually nothing. A thinner wall smaller diameter pushrod is going to bend permanently before a thicker wall larger diameter pushrod. Both will deflect, but just not the same amount.
I'm not really trying to say anything one way or another or trying to "push" an agenda, just adding to the discussion.
